Cisco WS-C3850-48T with Errors on Startup
Hi alle we have a 3850 with Errors on Startup:
Booting...Initializing and Testing RAM +++@@@@####...++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@done.
Memory Test Pass!
Base ethernet MAC Address: 0c:27:24:96:4d:80
Interface GE 0 link down***ERROR: PHY link is down
Initializing Flash...
flashfs[7]: 0 files, 1 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 6784000
flashfs[7]: Bytes used: 1024
flashfs[7]: Bytes available: 6782976
flashfs[7]: flashfs fsck took 1 seconds....done Initializing Flash.
Getting rest of image
Reading full image into memory....done
Reading full base package into memory...: done = 74409080
Nova Bundle Image
Kernel Address    : 0x6042d350
Kernel Size       : 0x317ccc/3243212
Initramfs Address : 0x6074501c
Initramfs Size    : 0xdc645c/14443612
Compression Format: .mzip
Bootable image at @ ram:0x6042d350
Bootable image segment 0 address range [0x81100000, 0x81b80000] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 377
Loading Linux kernel with entry point 0x811060f0 ...
Bootloader: Done loading app on core_mask: 0xf
### Launching Linux Kernel (flags = 0x5)
All packages are Digitally Signed
Starting System Services
Jun 24 09:34:45 %IOSXE-3-PLATFORM: process kernel: ERROR LMC0 ECC: sec_err:1 ded_err:0
Jun 24 09:34:45 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing dimm: 0
Jun 24 09:34:45 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing rank: 1
Jun 24 09:34:45 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing bank: 5
Jun 24 09:34:45 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing row: 0xff34
Jun 24 09:34:45 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing column: 0x1034
Jun 24 09:34:45 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^Isyndrome: 0xb5
Jun 24 09:34:45 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing bank: 2
Jun 24 09:34:45 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing row: 0xf796
Jun 24 09:34:45 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing column: 0x1ae4
Jun 24 09:34:54 %IOSXE-3-PLATFORM: process kernel: ERROR LMC0 ECC: sec_err:1 ded_err:0
Jun 24 09:34:54 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing dimm: 0
Jun 24 09:34:54 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing rank: 1
Jun 24 09:34:54 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing bank: 2
Jun 24 09:34:54 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing row: 0xf70a
Jun 24 09:34:54 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing column: 0x2be4
Jun 24 09:34:54 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^Isyndrome: 0xb5
Jun 24 09:35:13 %IOSXE-3-PLATFORM: process kernel: ERROR LMC0 ECC: sec_err:1 ded_err:0
Jun 24 09:35:13 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing dimm: 0
Jun 24 09:35:13 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing rank: 1
Jun 24 09:35:13 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing bank: 7
Jun 24 09:35:13 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing row: 0xff9c
Jun 24 09:35:13 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing column: 0x3170
Jun 24 09:35:13 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^Isyndrome: 0xb5
Jun 24 09:35:57 %IOSXE-1-PLATFORM: process stack-mgr: %STACKMGR-1-DISC_DONE: Switch 1 has finished stack discovery.
Jun 24 09:35:57 %IOSXE-1-PLATFORM: process stack-mgr: %STACKMGR-1-SWITCH_ADDED: Switch 1 has been added to the stack.
Jun 24 09:35:58 %IOSXE-3-PLATFORM: process kernel: ERROR LMC0 ECC: sec_err:1 ded_err:0
Jun 24 09:35:58 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing dimm: 0
Jun 24 09:35:58 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing rank: 1
Jun 24 09:35:58 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing bank: 4
Jun 24 09:35:58 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing row: 0xbd28
Jun 24 09:35:58 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing column: 0x21a8
Jun 24 09:35:58 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^Isyndrome: 0xb5
Jun 24 09:35:59 %IOSXE-3-PLATFORM: process kernel: ERROR LMC0 ECC: sec_err:1 ded_err:0
Jun 24 09:35:59 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing dimm: 0
Jun 24 09:35:59 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing rank: 1
Jun 24 09:35:59 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing bank: 4
Jun 24 09:35:59 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing row: 0xbc17
Jun 24 09:35:59 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing column: 0x1fd4
Jun 24 09:35:59 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^Isyndrome: 0xb5
Jun 24 09:36:00 %IOSXE-3-PLATFORM: process kernel: ERROR LMC0 ECC: sec_err:1 ded_err:0
Jun 24 09:36:00 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing dimm: 0
Jun 24 09:36:00 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing rank: 1
Jun 24 09:36:00 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing bank: 2
Jun 24 09:36:00 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing row: 0xc398
Jun 24 09:36:00 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing column: 0x216c
Jun 24 09:36:00 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^Isyndrome: 0xb5
Jun 24 09:36:02 %IOSXE-3-PLATFORM: process kernel: ERROR LMC0 ECC: sec_err:1 ded_err:0
Jun 24 09:36:02 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing dimm: 0
Jun 24 09:36:02 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing rank: 1
Jun 24 09:36:02 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing bank: 6
Jun 24 09:36:02 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing row: 0xb9d0
Jun 24 09:36:02 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing column: 0x94
Jun 24 09:36:02 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^Isyndrome: 0xb5
Jun 24 09:36:04 %IOSXE-3-PLATFORM: process kernel: ERROR LMC0 ECC: sec_err:1 ded_err:0
Jun 24 09:36:04 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing dimm: 0
Jun 24 09:36:04 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing rank: 1
Jun 24 09:36:04 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing bank: 2
Jun 24 09:36:04 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing row: 0xb483
Jun 24 09:36:04 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing column: 0xdc8
Jun 24 09:36:04 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^Isyndrome: 0xb5
Jun 24 09:36:05 %IOSXE-3-PLATFORM: process kernel: ERROR LMC0 ECC: sec_err:1 ded_err:0
Jun 24 09:36:05 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing dimm: 0
Jun 24 09:36:05 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing rank: 1
Jun 24 09:36:05 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing bank: 4
Jun 24 09:36:05 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing row: 0xbacf
Jun 24 09:36:05 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing column: 0x3f10
Jun 24 09:36:05 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^Isyndrome: 0xb5
Jun 24 09:36:09 %IOSXE-1-PLATFORM: process stack-mgr: %STACKMGR-1-ACTIVE_ELECTED: Switch 1 has been elected ACTIVE.
Jun 24 09:36:14 %IOSXE-3-PLATFORM: process kernel: ERROR LMC0 ECC: sec_err:1 ded_err:0
Jun 24 09:36:14 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing dimm: 0
Jun 24 09:36:14 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing rank: 1
Jun 24 09:36:14 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing bank: 7
Jun 24 09:36:14 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing row: 0xae6e
Jun 24 09:36:14 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing column: 0x3b24
Jun 24 09:36:14 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^Isyndrome: 0xb5
Jun 24 09:36:15 %IOSXE-3-PLATFORM: process kernel: ERROR LMC0 ECC: sec_err:1 ded_err:0
Jun 24 09:36:15 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing dimm: 0
Jun 24 09:36:15 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing rank: 1
Jun 24 09:36:15 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing bank: 2
Jun 24 09:36:15 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing row: 0xfba6
Jun 24 09:36:15 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing column: 0x1b94
Jun 24 09:36:15 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^Isyndrome: 0xb5
Jun 24 09:36:15 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing bank: 3
Jun 24 09:36:15 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing row: 0xbc9c
Jun 24 09:36:15 %IOSXE-3-PLATFORM: process kernel: LMC0 ECC:^IFailing column: 0x312c
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.02.01.SE RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 20-Mar-13 17:10 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
% Error! No serial number found for this platform.
cisco WS-C3850-48T (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FOC1720V26R
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of  at webui:.
Base Ethernet MAC Address          : 0c:27:24:96:4d:80
Motherboard Assembly Number        : 73-12239-05
Motherboard Serial Number          : xxxxxxxx
Model Revision Number              : B0
Motherboard Revision Number        : C0
Model Number                       : WS-C3850-48T
System Serial Number               : xxxxxxxx
         --- System Configuration Dialog ---
Enable secret warning
In order to access the device manager, an enable secret is required
If you enter the initial configuration dialog, you will be prompted for the enable secret
If you choose not to enter the intial configuration dialog, or if you exit setup without setting the enable secret,
please set an enable secret using the following CLI in configuration mode-
enable secret 0 <cleartext password>
Would you like to enter the initial configuration dialog? [yes/no]: n
Would you like to terminate autoinstall? [yes]:
Press RETURN to get started!
*Jun 24 09:37:42.043: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/2, changed state to down
*Jun 24 09:37:42.044: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/3, changed state to down
*Jun 24 09:37:42.044: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/4, changed state to down
*Jun 24 09:37:44.696: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
Switch>
The first Error is a BUg in the IMage but the Kernelerror´s ?
Can someone help me ?
Philipp
Leo Laohoo
Contact Cisco TAC.  I think your flash memory is failing.
