Ciso 4506 boot sequesnce
bapatsubodh
Here is the output from the 4506 1. show bootvar 2. show ver   3. show bootflash. I need to confirm that after reboot switch will boot with the specified image and will not go to RMON mode.
ABCD-1#sh bootvar
BOOT variable = sup-bootflash:cat4500-ipbase-mz.122-31.SGA6.bin,12;  -----------------------------------> set by "boot system sup-bootflash:cat4500-ipbase-mz.122-31.SGA6.bin"  command
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Configuration register is 0x2101
ABCD-1#sh version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASE-M), Version 12.2(31)SGA6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 31-Mar-08 21:23 by chendah
Image text-base: 0x10000000, data-base: 0x114B115C
ROM: 12.2(31r)SGA1
Dagobah Revision 226, Swamp Revision 4
ABCD-1 uptime is 13 weeks, 4 days, 22 hours, 21 minutes
System restarted at 08:37:41 PDT Sat Jul 23 2011
System image file is "bootflash:cat4500-ipbase-mz.122-31.SGA6.bin"
cisco WS-C4503 (MPC8245) processor (revision 4) with 262144K bytes of memory.
Processor board ID FOX1237GRHP
MPC8245 CPU at 267Mhz, Supervisor II+TS
Last reset from PowerUp
12 Virtual Ethernet interfaces
20 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101 ---------------------------------------------------------> config set "Boots the first system image in onboard Flash memory"
ABCD-1#show bootflash:
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1   .. image        03EDCAC2  BE5744   33 12211908 Nov 8 2008 03:02:30 -08:00 cat4500-ipbase-mz.122-31.SGA6.bin --------> Code image in flash
2   .. config       D252F402  BE7F2C   14    10085 Jun 25 2010 08:46:19 -07:00 abcd-1-confg
3   .. unknown      9670BEA1  BEC004    4    16471 May 2 2011 13:25:34 -07:00 tftp
15024124 bytes available (12238852 bytes used)
Please share the experience.
Thanks in advance
Subodh
nkarpysh
Hello Subodh,
As you are using explicit file for boot in boot varuable I would use 0x2102 confreg then which is asking router to use netboot variable.
Other things seem to be ok.
Nik
HTH,
Niko
