cisoc wan optimisers
cisco8887
Level 2
Level 2
Hi Guys,
I have read a bit about wan optimiser and trying to make sense of the following from the article below:
http://www.cisco.com/c/en/us/products/collateral/routers/wide-area-application-services-waas-software/solution-overview-c22-732054.html
Target WAN Bandwidth (Mbps) vs Optimized LAN Throughput (Mbps).
Taking 294 to consideration, does this mean a 10-20 mb line can carry an equivelent of 150Mb ?
I know latency plays a role in TCP connections and on maximum tcp window size of 64K without tcp scaling and a 100ms rtt link you can achive about achieve about 6.4Mbps(512000bps/0.100)=5.12
It only needs to connections to send data and saturate the line.
do they do massive compression ?
caching ?
so when cisco claims 10-20mb is 100-150 on Lan, how do they get this?
many thanks
WAVE Platform
WAVE 294
WAVE 594
WAVE 694
WAVE 7541
WAVE 7571
WAVE 8541
Network Location
Small Branch Office
Large Branch Office or Campus
Large Branch Office, Data Center, or Campus
Data Center or Campus
10-20
50-100
200
500
1,000
2,000
Number of Optimized TCP Connections Supported
200-400
750-1,300
2,500-6,000
18,000
60,000
150,000
100-150
250-300
450-500
1,000
2,000
4,000
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Often they do.
caching ?
Often they do.
Often, compression with caching.
The common trick is they often have some kind of token they send across the WAN link that indicates a block of data to be pulled from the local cache.
"Your mileage may vary".
