class-map match-any not working !!!
fritz001a
class-map match-any ONLINE_MOVIES
match protocol http host "www.moviesonline.ca"
match protocol http host "www.bestmovies.cc"
match access-group 190
policy-map DROP_ONLINE_MOVIES
class ONLINE_MOVIES
   drop
access-list 190 permit tcp host 192.168.40.5 any eq www
interface FastEthernet0/0
description _WAN_INTERFACE_
service-policy output DROP_ONLINE_MOVIES
however all class 192.168.40.0 /24 is banned !!
Am I missing something ?
cool
Don't forget to rate helpful posts and mark the thread as solved.
Regards.
Alain.
13 Replies 13
cadet alain
so you want to deny  this host to  browse these 2 sites? if so then you can do this:
class-map match-any URLS
class-map ONLINE_MOVIES
match class-map  URLS
Regards.
Alain
match protocol http host "*moviesonline.ca"
match protocol http host "*bestmovies.cc"
class-map match-all ONLINE_MOVIES
class ONLINE_MOVIES
   drop
interface Fa0/0
access-list 190 permit tcp host 192.168.40.203 any eq www
so... the policy doesn't seems to apply at all , i mean both IPs are able to browse the banned urls ...
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Could you clarify "all"?  The ACL should only block all destination port 80 traffic from 192.168.40.5.
Perhaps Alain has guessed what you intended?  If not, could you clarify what you want to accomplish?
PS:
To clarify part of Alain's posting:
When I was refering to "all"  I mean: 192.168.40.0/24  can not access those urls.
yes, the idea is to block access to those URLS only to specific _LAN hosts
Regarding my previous answer::
so i have to "translate" the policy as follow:
1.class urls
if any of url ==>MATCH
2.class online_movies
if any of urls AND IP1=192.168.40.5 AND IP2=192.168.40.203
or
if any of urls AND IP1=192.168.40.5 OR IP2=192.168.40.203
hi Florin,
can you please post the results of "sh policy-map interface fa0/0" here so that we can take a look
Rgds, Kishore
this one:
if any of urls AND (IP1=192.168.40.5 OR IP2=192.168.40.203)
Regards.
Alain.
Core_R1#sh policy-map interface fa0/0
FastEthernet0/0
  Service-policy output: DROP_ONLINE_MOVIES
    Class-map: ONLINE_MOVIES (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: class-map match-any URLS
        Match: protocol http host "www.moviesonline.ca"
          144 packets, 13264 bytes
          5 minute rate 0 bps
        Match: protocol http host "www.bestmovies.cc"
          0 packets, 0 bytes
          5 minute rate 0 bps
      Match: access-group 190
      drop
and the full config of fa0/0
mac-address _MAC_
ip address _IP_
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
ammahend
Paste the following ouputs
show policy-map int f0/0
show run int f0/0
show ip int br | ex un
sh ver | in image
Let me know if there is any tunnel or vpn session going on f0/0 interface , as it will hide your orignial ip header info .
Let me know the physical layout from host to router .
-hope this helps-
I do have an OPENVPN server running behind the router on host 192.168.40.222
Core_R1#sh ver | in image
System image file is "flash:c2600-advipservicesk9-mz.124-25d.bin"
Core_R1#show run int f0/0
Building configuration...
Current configuration : 304 bytes
mac-address ____
ip address _____
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
no cdp enable
end
Core_R1#show ip int br | ex un
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            _IP_          YES NVRAM  up                    up
FastEthernet0/1            _LAN_IP_  YES NVRAM  up                    up
NETWORK LAYOUT::
HOSTS-->Cisco 2950-->CISCO 2651XM
Can you try applying this policy inbound on the nat inside interface.
Regards.
Alain
interface FastEthernet0/1
description _LAN_INTERFACE_
service-policy input DROP_ONLINE_MOVIES
end
damn, it's working now
cool
Regards.
Alain.
Ivan Salazar
hello , i have this problem , i want to block some urls
this is my config , is only a example
match protocol http host "www.taringa.net"
policy-map DROP_TARINGA
class URL
   drop
ip address x.x.x.x 255.255.255.248
ip accounting output-packets
ip accounting precedence output
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
crypto map outside0_map
service-policy output DROP_TARINGA
this config, block all LAN ips  , iths WORKING, but i want to allow some ips witout block this urls...
for example i want to permit the ips 184.1.150.100 - 110  to this url , but block all the subnet,
this is my access-list
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 200.36.125.129
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip route 184.1.2.0 255.255.255.0 200.36.125.129
ip access-list extended testcrypto
permit ip 184.1.150.0 0.0.0.255 128.1.0.0 0.0.255.255
permit ip 184.1.150.0 0.0.0.255 130.1.0.0 0.0.255.255
permit ip 184.1.150.0 0.0.0.255 184.1.1.0 0.0.0.255
permit ip 184.1.150.0 0.0.0.255 184.1.2.0 0.0.0.255
permit ip 184.1.150.0 0.0.0.255 184.1.3.0 0.0.0.255
permit ip 184.1.150.0 0.0.0.255 192.168.160.0 0.0.0.255
permit ip 184.1.150.0 0.0.0.255 192.168.63.0 0.0.0.255
permit ip 184.1.150.0 0.0.0.255 184.1.5.0 0.0.0.255
permit ip 184.1.150.0 0.0.0.255 192.168.165.0 0.0.0.255
permit ip 184.1.150.0 0.0.0.255 192.168.142.0 0.0.0.255
logging esm config
access-list 100 remark SDM_ACL Category=2
access-list 100 deny   ip any host 184.1.150.200
access-list 100 deny   ip any host 184.1.150.201
access-list 100 deny   ip any host 184.1.150.202
access-list 100 deny   ip any host 184.1.150.203
access-list 100 deny   ip any host 184.1.150.204
access-list 100 deny   ip any host 184.1.150.205
access-list 100 deny   ip any host 184.1.150.206
access-list 100 deny   ip any host 184.1.150.207
access-list 100 deny   ip any host 184.1.150.208
access-list 100 deny   ip any host 184.1.150.209
access-list 100 deny   ip any host 184.1.150.210
access-list 100 permit ip 10.1.10.0 0.0.0.3 any
access-list 100 permit ip 10.1.1.0 0.0.0.255 any
access-list 189 deny   ip 184.1.150.0 0.0.0.255 184.1.1.0 0.0.0.255
access-list 189 deny   ip 184.1.150.0 0.0.0.255 128.1.0.0 0.0.255.255
access-list 189 deny   ip 184.1.150.0 0.0.0.255 130.1.0.0 0.0.255.255
access-list 189 deny   ip 184.1.150.0 0.0.0.255 184.1.2.0 0.0.0.255
access-list 189 deny   ip 184.1.150.0 0.0.0.255 184.1.3.0 0.0.0.255
access-list 189 deny   ip 184.1.150.0 0.0.0.255 184.1.4.0 0.0.0.255
access-list 189 deny   ip 184.1.150.0 0.0.0.255 192.168.160.0 0.0.0.255
access-list 189 deny   ip 184.1.150.0 0.0.0.255 192.168.63.0 0.0.0.255
access-list 189 deny   ip 184.1.150.0 0.0.0.255 192.168.142.0 0.0.0.255
access-list 189 permit ip any any
access-list 190 deny   tcp host 184.1.150.110 any eq www
route-map SDM_RMAP_1 permit 1
match ip address 100 189
________________________________________________________
LAN interface
interface BVI1
ip address 184.1.150.1 255.255.255.0
ip nat inside
WAN interface
ip nat outside
duplex auto
speed auto
some , people , helpme please
