Class-map used by two policies in the same interface and router
alison.hou
Here is the configs:
class-map match-any Voice
match ip dscp ef
policy-map INBOUND
class Voice
   priority percent 40
   set dscp ef
class class-default
   fair-queue!
policy-map OUTBOUND
class Voice
   priority 1000
class class-default
   fair-queue!
interface ATM1/ima0.1 point-to-point
service-policy input INBOUND
service-policy output OUTBOUND
Can this work?
Alison
5 Replies 5
marcusauman
Yes you can reference a class map in multiple policies. Configuration looks good as well minus the ! at the end of your fair-queue statements.
Please rate if this was helpful.. Thanks
cadet alain
of course you can use the same class-map on different policy-maps , that's why MQC was created for: modularity and reuse
BUT in your case your policy can't be applied inbound because you can only configure CBWFQ or LLQ outbound( bandwidth or priority command) because this is a congestion management feature and congestion occurs on egress queues.
Alain.
Alain is correct. Good catch!
Thank you for the catch. My goal is to retrict traffic from a microsoft DS server in the data center to this remote site. The outbound qos policiy is the existing policy for voice. For the inbound, I am planning to add a class for micorsoftDS to give it 3% bandwidth. How should I do it if I can't use CBWFQ or LLQ for inbound.
match ip dscp ef
class-map microsoftDS
            match access group 102
policy-map VoIP_COS
  class Voice
    priority 1000
  class class-default
   fair-queue
policy-map LLQ_40percent
class Voice
   priority percent 40
   set dscp ef
class microsoftDS
   bandwidth percent 3
class class-default
   fair-queue!
access-list 102 permit tcp host 10.80.14.140 eq 445 any
access-list 102 permit udp host 10.80.14.140 eq 445 any
service-policy input LLQ_40percent
service-policy output VoIP_COS
alison
use the police keyword instead of priority.
Regards.
Alain.
