Clear configuration files on Switch to factory defaults
paul dungey
Good Morning,
I have a 4500 Catalysts switched (4510 R ) that require the configuration to wiped back to factory default setting,
How would i go about clearing the configuration on each module board
Sorry if this question has been asked before
The chassis consists of
2 x Supervisor engines v WS-X4516 with Flash cards
4 x WS x84448 GB RJ45 48 port switches
1 x  WS x4306 GB Switch Module
I also have a Catalyst 6500 that requires each module within the chassis to we wiped back to factory defaults
1 x Supervisor engine WS X 6k SUP 2- 2GE
1 x WS X6416 G-Bic 16 port GB Ethernet
4 X WS X 6148 CE-TX Base T GE 10/100/1000
1 x WS X6348 48 Port Inline Power Capable
And i have a Catalyst WS - C 6513 with the following Module card that need the configuration wiped to Factory defaults as well
andrew.prince
Level 10
Level 10
running CatOS or IOS?
Hi Andrew
The following text is taken from my Catalyst 4510 R,
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12
.2(25)EWA8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 24-Jan-07 14:38 by pwade
Image text-base: 0x10000000, data-base: 0x114EECF0
Compressed configuration from 58171 bytes to 16787 bytes[OK][OK]
*       STANDBY SUPERVISOR        *
*     REDUNDANCY mode is SSO      *
*        Continue bootup          *
cisco WS-C4510R (MPC8245) processor (revision 4) with 524288K bytes of memory.
Processor board ID FOX11100GNE
MPC8245 CPU at 400Mhz, Supervisor V
Last reset from PowerUp
250 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Compress config cannot be disabled
Successfully configured from rcsf file, ha_alternate_parse TRUE
You want the correct way or the quick-n-nasty way?
Correct Way
1.  Erase the VLAN.dat file;
2.  Erase the config using the command "wr erase"; and
3.  Make sure you don't have any other files there other than the IOS in your CF or your supervisor flash.
Quick-n-nasty Way
1.  Command:  "format flash:"  (I don't know if the card you are using has a supervisor-disk but you can use the command "format ?" to find out.)
2.  Done.
