Client directly connected to switch port
perpaal
I will be connecting some clients directly to switchports.
But I`m really sceptical to do this, as it may create problems in my network.
The clients will connect to client VLANs with /25 mask, and use public IPs through DHCP or static IP.
I`m planning on using IP source guard for the clients with static IPs and DHCP snooping for the DHCP clients.
What more restrictions should I put on the interfaces/VLANs to  make this as lttle painfull as possible?
Leo Laohoo
1.  spanning-tree bpduguard enable
2.  MAC security limit to one MAC address
3.  DHCP snooping
Thank you, these are good tips, will iplement it.
Any more tips?
PVLANs combined with ACLs are also an option. DHCP snooping & DAI would be added security.
Samir
microfeel
Hi perpaal!
4. Configure VACL and apply it to a VLAN.
5. Allow VLANs wich are assigned by you or someone for your WAN/LAN.
