CLNS ISIS routing
boonteongng
I have 2 Areas running CLNS ISIS, say Area 1 and Area 2. Can the specific address in the database of area 1 router be seen at routers in area 2 ? or the routers in area 2 just see a prefix for the net in area 1 instead of the specific address ?
pkhatri
Level 11
Level 11
You will only see the area addresses for each area in the other area, and not specific addresses. That is part of the summarisation done by L2 routers.
Hope that helps - pls rate the post if it does.
Paresh
