CLOSED
aryarahul
I have a LMS Configured in my Network...from the last 2 days i am experiencing a new problem...
The LAN Interface of one Router in the Network automatically shutsdown...
Kindly Help
5 Replies 5
sukh_ynr1
what config you have in the LAN interface?
hobbe
Level 7
Level 7
What does your log on the router tell you ?
8 of 10 times you will get the answer from your logs in cases like this.
I would start in that end.
Good luck
Ivan Shirshin
Hi Rahul,
Please share logs, "show interface" and running config for interface.
Kind Regards,
Ivan
Kind Regards,
Ivan
#######sh interfaces fastEthernet 0/1
FastEthernet0/1 is up, line protocol is up
  Hardware is Gt96k FE, address is 0016.c735.d129 (bia 0016.c735.d129)
  Description: !!LAN!!
  Internet address is 172.16.x.x/xx
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 3/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 23:33:53
  Input queue: 0/75/1/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 486000 bits/sec, 145 packets/sec
  5 minute output rate 1271000 bits/sec, 168 packets/sec
     6223013 packets input, 865576141 bytes
     Received 203327 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     6426992 packets output, 2369707738 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
Doesn't say much with the output.  How about the "sh logs" (as Ivan has requested)?  How about the config of the router interface?
