CMNS support is not present in this image
We are using a C1721 router to connect a X25 line to an ethernet port. We need to enable CMNS and we get the following error:
GDM_Cisco#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
GDM_Cisco(config)#interface fastethernet0
GDM_Cisco(config-if)#cmns enable
This is the device information:
GDM_Cisco>show hardware
IOS (tm) C1700 Software (C1700-ADVSECURITYK9-M), Version 12.3(15), RELEASE SOFTW
ARE (fc3)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 24-May-05 21:33 by ssearch
Image text-base: 0x8000816C, data-base: 0x81012AF4
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-ADVSECURITYK9-M), Version 12.3(15), RELEASE SOFTWARE
(fc3)
Any help would be useful.
Fernando L
ilker.ekinci
Dear sir, you should throw cisco from the top of the mountain !
ilker
