communication between a GBIC LX module and an SPF SX module
scottmic35
Is it possible to have a GBIC LX module talk to an SPF SX module across mutimode fiber?
5 Replies 5
thisisshanky
Level 11
Level 11
No, they cannot, unless you use a converter. They use differnt wavelengths, freq's.
http://www.cisco.com/en/US/products/hw/modules/ps872/products_data_sheet09186a008014cb5e.html
PS: Please remember to rate replies!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
thanks, what is this converter? Is it something Cisco provides and if so do you know what it is?
I am not aware of a product that Cisco makes which does this, unless you use a Cisco switch with LX gbic and SX gbic and then connect the remote ends via fiber to these gbics (extra hop through this switch).
Also take a look at this third party converter.
http://www.netoptics.com/products/product_family_details.asp?cid=5&pid=59&Section=products&menuitem=5
Just google on SX to LX converter and you will find many links like above.
PS: Please remember to rate helpful replies!
Sankar Nair
I will do that...one last question..the incompatibility is not because one is a GBIC and one is an SPF but just that one is an LX and one is an SX correct?
You are correct. It's not the physical shape of the optical transceiver, but rather the difference in wavelengths used (Gigabit SX=850nm, LX/LH=1300nm) that causes the problem.
Although physical shape does play a role when you go to install the component: you can't put an SFP in a GBIC slot, and you can't put a GBIC in an SFP slot.
I have several switch-to-router and switch-to-switch connections where there is an SFP at one end of the link (newer equipment), and a GBIC at the other end (older equipment). As long as the optical transceivers at each end use the same wavelength, and the fiber patch cable has appropriate connectors for each end (LC for SFP, and SC for GBIC), you can connect SFPs to GBICs.
