Community List manipulation in BGP
arun kumar
We are receiving prefixes from our partners with multiple communities set which is specific to the locations. Say for exampls
xxxx:xxaa
xxxx:xxab
xxxx:xxac
Similar to the above one.
I want to set the preference high for all the communities xxxx:xx-- the last 2 digits can be any value.
The last 2 digits are actually dont care bits.
One way is to define the community list with as many entries as the communities that i m receiving from the partner and set the local preference with route map. But the problem here is i m receiving around 50 communities from the same partner.
I want to add a single entry in community list with last 2 digits being dont care.
somthing like
ip community-list test permit xxxx:xx**
Is it any way I can achieve this.
thanks
Arun Kumar
Giuseppe Larosa
Hello Arun,
this is possible using expanded community-list.
see
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_bgp2.html#wp1016057
the command should be
ip community-list expanded test permit xxxx:xx*
one wildcard should be enough
Hope to help
Giuseppe
