Community list regex question
anthonykahwati
Can anyone help me with an expanded community list regex question please?
I couldn't get the below to work. It just picked up nothing, although, on online regex checkers it works:
^(649[0-9][0-9]):(.{1,5})$
I did manage to get the following working though:
649[0-9][0-9]:*
If anyone can let me know where I'm going wrong that would be appreciated.
Many thanks
What do you need to match ? In expanded community lists, regular expressions are used to specify patterns to match COMMUNITIES attributes; the syntax you use looks like you are trying to filter on AS.
Thanks for replying.
I am trying to match a community list with a name of say 649XX:YYY_CL and it should match any community that starts 649 plus 2 more digits, has a : in the middle and then between 1 and 5 additional characters..
It's definitely trying to match the community value but the AS number of where the traffic came from helps create the actual community value that is assigned to a route.
Hi there,
The second part of your regex (after the colon) does not match enough charecters for your example. It should be:
^(649[0-9][0-9]):(.{1,6})$
...but this can be improved a little:
^649\d{2}:.{1,6}$
cheers,
Seb.
Hey Seb
Thanks very much. I’ll give it a go.
out of curiosity, do the Cisco routers support the full range of regex characters and behaviours?
Cheers.
