Compatible switch
irwanamri
please help me to find out compatible switch for 2851 cisco router...
guruprasadr
Level 7
Level 7
Any Cisco Switch is Compatible (Note:Switch should support both L2 & L3 capability). It depends upon your LAN Segment & Business Requirement, etc.,
Pls Rate if Helps
Best Regards,
Guru Prasad R
spremkumar
Level 9
Level 9
You can think off using an Ehter Switch module itself instead of using a seperte L2 Switch.
You can check this link out for more info on the kinda ESW modules supported by Cisco 2851 router..
http://www.cisco.com/en/US/products/ps5854/products_data_sheet0900aecd8016fa68.html
regds
Any cisco L2 and L3 switch is compatible,depending on your network requirement.
