Conditional NAT
pushpak.lele
We need to implememt conditional nat in a test setup.
Please refer attched ppt for the diagram.
Kindly let us kow how this can be configured cause we tried using route-map with deny statement but its not working.
Please help
Thanks And Regards
Pushpak
Hello
What is it you want to NAT?
Res
Paul
Kind Regards
Paul
From R5 i will try toaccess 10.9.22.1 with source 10.1.1.1 in this 10.9.22.1 should get translated to 10.8.55.1. ( For 10.9.22.1  10.8.55.1 should reply )
From R5 i will try to access 10.9.22.1 with source 10.1.1.2 in this should  10.9.22.1 should go untranslated . ( 10.9.22.1 will reply ).
Thanks And Regards
Pushpak
Hello
10.8.55.1 is located on r1 so why do you wish to NAT sourced from an ip on r5 using r1 IP address when communicating to an IP address on R2?
res
Paul
Kind Regards
Paul
