Config register problem
farancci1
Community Member
I have a 2621 router and I am trying to change my config register value to 0x2102 (config-register 0x2102) however whenever I change it it comes back as 0x3102. I even tried to change the jumper setting but once it boors up it takes the 0x3102 as the register value.
This is what I get after setting the jumper value, eventhough it shows the 0x2102 as current value however its not because I have to change by baud rate to 1200 once it reboots completed. I have tried 12.0 and 12.2 IOS version
{"Configuration register is 0x2102 will be 0x3102 at next reload)")
8 Replies 8
Richard Burts
Muhammad
I think I had a similar problem one time. Please look in your configuration under line console 0 and see if there is a speed command configured. If there is remove it and try to set the config register again.
If that does not fix it, please capture and post the output of a terminal session that includes a show version, a config t, config-register 0x2102, and a show version.
Rick
Rick
You were right the speed on cosole wast set 1200 and that fixed the problem. I appreciate your help Thanks
I have had this problem on a Cisco 877 router and have taken the advice. The problem I was having affected the stability of the router with it sometimes hanging. However, now I have resolved this I still get the output
Configuration register is 0x2102 (will be 0x3102 at next reload). I have even tried hard setting the config -register again but it still has this output. Is it safe to reload or is this risky?
Jeremy
Have you done a copy running-config startup-config (or a write mem) since making the config changes?
Can you post the output of show run | begin line con
also the output of show start | begin line con
and the output of show version?
Perhaps with this information we will be better able to judge how safe it is to reload.
Rick
Rick
Hi Rick,
Thanks for your reply. Please see output below.
Peacocks_Store567#sho run | begin line con
line con 0
password
login
no modem enable
transport output all
line aux 0
script dialer DIALOUT
transport input all
flowcontrol hardware
line vty 0 4
password
logging synchronous
login
transport input all
scheduler max-task-time 5000
sntp server 88.151.217.68
end
Peacocks_Store567#sho start | begin line con
line con 0
password Convergence1999
login
no modem enable
line aux 0
transport input all
line vty 0 4
logging synchronous
login
transport input all
end
Peacocks_Store567#sho ver
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(4)T8, REL
EASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Sat 11-Aug-07 03:34 by khuie
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Peacocks_Store567 uptime is 18 hours, 1 minute
System returned to ROM by reload at 15:36:04 GMT Mon Nov 19 2007
System restarted at 15:42:47 GMT Mon Nov 19 2007
System image file is "flash:c870-advsecurityk9-mz.124-4.T8.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 877 (MPC8272) processor (revision 0x300) with 118784K/12288K bytes of memo
ry.
Processor board ID FCZ114490M9
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
Jeremy
Thanks for posting the information that I requested. It does clearly show that there is not a speed command under the line console 0. So I am surprised that show version shows that the config register will change at reload. I have tried to reproduce the symptoms on a router I have access to and can not produce the symptom.
I am not sure what to suggest next. You might try setting the config register one more time (just in case there was a typo when you did it before). Or you might post the entire router config so we can see if there might be something else causing this. Or you might just go ahead and reload the router. I believe that the only thing that might happen would be the possibility that the console speed would change after reload and you would have to change speed in your terminal emulator software to access the console. I do not see any impact beyond that (and I am not entirely sure that this would happen).
Rick
Rick
Hi Rick,
Please find complete config:
version 12.4
no service pad
hostname Peacocks_Store567
boot-start-marker
boot-end-marker
logging buffered 50000 debugging
enable secret
no aaa new-model
resource policy
clock timezone GMT 0
clock summer-time BST recurring
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 90.x.x.1 90.5.67.159
ip dhcp excluded-address 90.x.x.169 90.5.67.254
ip dhcp pool Peacocks
import all
network 90.x.x.0 255.255.255.0
default-router 90.5.67.200
dns-server 89.10.2.244
lease 0 12
chat-script DIALOUT ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 120 CON
NECT \c
modemcap entry MY_USR_MODEM:MSC=&F0X2L1M0S0=1
track 100 interface ATM0 line-protocol
class-map match-all SAREBO
match access-group 1
policy-map shapetraffic
class SAREBO
bandwidth 200
class class-default
fair-queue
interface Loopback1
description MGMT Address
ip address 50.x.x.67 255.255.255.255
interface ATM0
backup delay 10 0
backup interface Dialer2
no ip address
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 90.x.x.200 255.255.255.0
ip policy route-map clear-df-bit
interface Async1
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 2
async mode dedicated
routing dynamic
interface Dialer2
bandwidth 64
ip address negotiated
encapsulation ppp
dialer pool 2
dialer remote-name peacocksbackup
dialer idle-timeout 180
dialer string 08456629011
dialer hold-queue 10
dialer-group 2
fair-queue
no cdp enable
ppp authentication pap chap callin
ppp chap hostname [email protected]
ppp chap password
interface Dialer1
bandwidth 288
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
no cdp enable
ppp authentication chap callin
ppp chap password
service-policy output shapetraffic
router rip
version 2
network 10.0.0.0
network 50.0.0.0
network 90.0.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1 track 100
ip route 0.0.0.0 0.0.0.0 Dialer2 200
no ip http server
no ip http secure-server
kron occurrence shopclosed at 17:35 recurring
policy-list shutdialer2
kron occurrence shopopen at 8:25 recurring
policy-list opendialer2
kron policy-list opendialer2
cli ifchange d2 on
kron policy-list shutdialer2
cli ifchange d2 off
access-list 1 permit 90.5.67.100
access-list 199 permit ip any any
dialer-list 2 protocol ip permit
snmp-server community convergence RO
snmp-server enable traps tty
no cdp run
route-map clear-df-bit permit 10
match ip address 199
set ip df 0
control-plane
line con 0
password
login
no modem enable
line aux 0
transport input all
line vty 0 4
password
logging synchronous
login
transport input all
end
Jeremy
Thank you for posting the config. I have looked at it and I do not see anything that clearly explains the symptom. The one thing I see that I wonder about it the command:
no modem enable
I do not normally see that in configs under line con 0. Perhaps it is normal on this platform, but it is a surprise to me. I wonder what would happen if you remove that command?
Otherwise I do not see anything else to do other than to reboot the router and see what happens.
Rick
Rick
