Config Revert command?
ubsaccount
Level 2
Level 2
When I try to do a config revert of a Cisco 4451 code 16.03.5 an message comes up.  I was wondering if anyone know what it is?
config t revert timer 10
%No Rollback Confirmed Change pending
I enabled archive path flash:
should I do archive path bootflash: instead?
5 Replies 5
Seb Rupik
Hi there,
Maybe try and confirm a configuration change:
configure confirm
You should now see an entry in show archive, which means your config t revert timer 10 should work .
cheers,
Seb.
configure confirm
Hi there,
Can you confirm that the archive feature is enabled? What is the output of sh archive ?
cheers,
Seb.
I figured out the problem.  You need to put config terminal revert timer  command
Rajesh Hirani
Level 2
Level 2
Try the bootflash..
