Configuration help- VLANS gateway /DCHP and hsrp
JahanzebA
  i am working in the lab and stuck at one point , need suggestions on solution to this prob. LAB screenshot is attached for reference
Two switch are connected to each other via trunk link and both have Vlan 10 and Vlan 20 configured on them.
SVIs are not defined on the switch
e3/3 in another trunk link connecting to routers from each switch and routers are then connected to ISP
Currently each router is configured with sub interfaces  f0/0.10 and f0/0.20 and respective VLANS gateway IP in configured on each sub int respectively
now problem is how to configure DHCP on these routers for each respective vlans . and secondly i want to use HSRP between these two routers , R372501 being active for VLAN 10 and R372521 active for VLAN 10
i have configured but DHCP doesn't work and neither VPC is able to ping gateway
pls suggest some solution or design suggestion so that i can achieve this
the below configs should work. You need to split the DHCP pools. The lower router is the Active HSRP router for Vlan20 and the Standby for Vlan10, the upper router is the reverse.
375520
ip dhcp excluded-address 1.1.1.1 1.1.1.3
ip dhcp excluded-address 1.1.1.128 1.1.1.254
ip dhcp excluded-address 2.2.2.1 2.2.2.3
ip dhcp excluded-address 2.2.2.128 2.2.2.254
ip dhcp pool VLAN10_LOWER_HALF
network 1.1.1.0 255.255.255.0
default-router 1.1.1.1
dns-server 8.8.8.8
ip dhcp pool VLAN20_LOWER_HALF
network 2.2.2.0 255.255.255.0
default-router 2.2.2.1
dns-server 8.8.8.8
interfaceFastEthernet0/0.10
description Subinterface for Vlan 10 HSRP Active
encapsulation dot1q 10
ip address 1.1.1.2 255.255.255.0
standby 10 ip 1.1.1.1
standby 10 priority 110
standby 10 preempt
interfaceFastEthernet0/0.20
description Subinterface for Vlan 20 HSRP Standby
encapsulation dot1q 20
ip address 2.2.2.2 255.255.255.0
standby 20 ip 2.2.2.1
375521
ip dhcp excluded-address 1.1.1.1 1.1.1.127
ip dhcp excluded-address 2.2.2.1 2.2.2.127
ip dhcp pool VLAN10_UPPER_HALF
dns-server 8.8.8.8
ip dhcp pool VLAN20_UPPER_HALF
dns-server 8.8.8.8
ip address 1.1.1.3 255.255.255.0
ip address 2.2.2.3 255.255.255.0
standby 20 priority 110
standby 20 preempt
6 Replies 6
JahanzebA
375520
dns-server 8.8.8.8
dns-server 8.8.8.8
standby 10 preempt
375521
dns-server 8.8.8.8
dns-server 8.8.8.8
standby 20 preempt
Thanks Georg i appreciate your time and help. i have configured like you said, i had almost same config as well and i was just missing dhcp excluded part.
But i ran into a new prob, VPCS are not getting ip from DHCP. which i m still trying to figure out
JahanzebA
i just noticed, VLAN VPCS on R18 are not getting response from DHCP server . i did capture packets using wireshark and i see both routers 375521and 375520 are getting dhcp discover but no response after that and Clients says no DHCP server found
For VPCS on R9 are fine, they get ip from DHCP.
any thoughts on this
post the full running configs of both routers...
JahanzebA
372520#sh running-config
Building configuration...
Current configuration : 1735 bytes
version 12.4
hostname 372520
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip dhcp use vrf connected
ip dhcp pool POOL_VLAN10
dns-server 8.8.8.8
ip dhcp pool POOL_VLAN20
no ip domain lookup
archive
log config
hidekeys
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
standby 1 ip 1.1.1.1
standby 1 priority 110
standby 10 preempt
interface FastEthernet0/0.20
encapsulation dot1Q 20
standby 2 ip 2.2.2.1
interface FastEthernet0/1
no ip address
ip nat inside
ip virtual-reassembly
shutdown
duplex auto
speed auto
interface FastEthernet0/1.10
router ospf 1
log-adjacency-changes
network 2.2.2.0 0.0.0.255 area 0
network 3.3.3.0 0.0.0.255 area 0
network 4.4.4.0 0.0.0.255 area 0
network 100.100.100.0 0.0.0.255 area 0
network 192.168.1.0 0.0.0.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 100.100.100.10
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
372520#
372521#sh running-config
Current configuration : 1287 bytes
version 12.4
hostname 372521
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
archive
log config
hidekeys
no ip address
duplex auto
speed auto
shutdown
standby 2 priority 110
standby 2 preempt
no ip address
shutdown
duplex auto
speed auto
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
372521#
