- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-24-2008 01:27 AM - edited 03-04-2019 12:28 AM
I have established a new ATM/DSL from my service provider and i have cisco 1841 router. May help me to configure my router?
Note i have a TG605s Thomson modem for direct connect to ATM circuit then RJ45 Ethernet from modem to cisco 1841 WAN module.
My circuit information is:
PVC number 1/311
interface ATM0/0.35 point-to-point description ATM0/0.35 atm pvc vpi=0 vci=35.
By VPNSC: Job Id# = 23186
ip address 172.31.148.174 255.255.255.252
pvc 0/35 encapsulation aal5snap
router bgp 64555 neighbor 172.31.148.173 remote-as 65000 redistribute connected
metric 1
no auto-summary
Solved! Go to Solution.
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-24-2008 02:55 AM
Hello Mostafa,
some more information is needed:
in the current setup the router lan interface is configured for:
a) receiving an ip address via DHCP
check if there is ip address dhcp or there is an ip address manually assigned
b) uses PPPoE encapsulation and receives an ip address during PPP negotiation:
check if there are commands containing
pppoe keyword under the fas interface
Depending on the find outs the configuration follow.
If not using PPPoE you have Classic IP over ATM.
int atm0/0
no shut
int atm0/0.35 point-to-point
ip nat outside
pvc 0/35
notice in this case you may need to configure NAT to make clients on the LAN able to surf the internet
int fas0/0
ip nat inside
ip nat inside source list 1 interface atm0/0.35 overload
access-list 1 permit lan.subnet lan.wildcardmask
If using PPPoE config is different but I think you should be fine with this
Hope to help
Giuseppe
check on the lan interface
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-24-2008 04:17 AM
Hello Mostaba,
no PPPoE and no need for NAT.
for BGP you just need to advertise the local lan IP subnet
router bgp xxx
network local.lan local.lan.mask
no auto-summary
you have already the neighbor statement configured.
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-24-2008 05:16 AM
Hello Mostafa,
here it is:
SiteA:
router bgp 64555
no auto-summary
no sync
neigh 172.31.148.173 remote-as 65000
network 172.18.6.0 255.255.255.0
note:
you are probably in a L3 MPLS VPN service.
In this case your router has an eBGP session with the PE node of the service provider.
the same is done on HQ
HQ
router bgp 64555
no auto-sum
no sync
neigh x.x.x.x remote-as 65000
network 172.18.0.0 255.255.255.0
the Service Provider signalling infrastructure will propagate your advertisements end to end and you will receive the remote lan IP subnet as originated in AS 65000.
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-24-2008 02:55 AM
Hello Mostafa,
int atm0/0
no shut
ip nat outside
pvc 0/35
int fas0/0
ip nat inside
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-24-2008 04:04 AM
Hello Qiusiar,
a)the router LAN interface will be configured to manual assigned IP.
b)no need to use PPPoE because this router to VLAN-to-VLAN (Branch-to-HQ office) connection through our Service provider IP-VPN/ATM cloud.
VLAN01: 172.18.6.0/24 Branch
VLAN02: 172.18.0.0/24 HQ office
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-24-2008 04:10 AM
Hello Qiusiar,
Also i asked:
Is there no configuration needed into BGP?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-24-2008 04:17 AM
Hello Mostaba,
router bgp xxx
no auto-summary
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-24-2008 04:23 AM
May i have you post the BGP configuration regarding to the data specified because this is the first time i configure cisco BGP?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-24-2008 05:16 AM
Hello Mostafa,
here it is:
SiteA:
router bgp 64555
no auto-summary
no sync
note:
HQ
router bgp 64555
no auto-sum
no sync
Hope to help
Giuseppe
