configure atm interface
jose.jimenez
How do I add this to a router?
interface ATM0/0/0
description ATM Circuit 24.HCGJ.xxxxxx
no ip address
no scrambling-payload
no atm ilmi-keepalive
interface ATM0/0/0.36 point-to-point
description Grant Street
ip address 10.XXX.XXX.XXX 255.255.255.252
pvc 1/36
ubr 1382
encapsulation aal5snap
Thanks again!
10 Replies 10
mohammedrafiq
interface ATM x/y
no ip address
interface ATM x/y.36 point-to-point
pvc 1/36
How do I add that information to router?
after going into conf t mode, do I need to type each line individually?
you can , or copy the above into notepad, change interface number,description and ip address, then paste all after conf t.U might have to add PVC again.
Thanks mohammedrafig.....
In order to cut and paste, is that done with Hyperterminal? If so, I just tried it and here's how I did that.
1.type conf t
2.copy contents from notepad
3.paste to host
after doing that, I get a % invalid input detected at ?? marker. What am I doing wrong?
can you send us out put of this command,
"sh ver"
This is sho ver
LEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 06-Nov-06 02:36 by alnguyen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
SLB_Grant_St uptime is 20 hours, 3 minutes
System returned to ROM by reload at 20:58:49 UTC Mon Jul 16 2007
System image file is "flash:c2800nm-spservicesk9-mz.124-3g.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX1122A2PV
2 FastEthernet interfaces
1 ATM interface
1 Channelized T1/PRI port
1 ATM/Voice AIM
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Looks like ur router have not detected the ATM car, or u forgot to install it.
Please send the output of following command
"sh ip int brief"
"sh ver"
This is "sh ip int brief"
SLB_Grant_St#sh ip int brief
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0/0 10.101.36.1 YES NVRAM up down
FastEthernet0/1 unassigned YES NVRAM administratively down down
ATM0/2/0 unassigned YES unset down dow
U should be able to add the config line by line like this,
SLB_Grant_St# conf t
SLB_Grant_St(conf)#int ATM0/2/0
no ip address
interface ATM 0/2/0.36 point-to-point
pvc 1/36
Hi Mohameedrafig,
I am working with another router (2811) and am trying to config the ATM interface. In last post you helped me with slb_grant. Can you please tell me how to add this command to the router?
interface ATM1/0
description 26HCGJXXXXXX
no ip address
ip nbar protocol-discovery
interface ATM1/0.36 point-to-point
bandwidth 1382
pvc 1/36
vbr-rt 1382 1382 1
tx-ring-limit 3
service-policy output Voice
interface ATM1/1
no ip address
shutdown
interface ATM1/2
no ip address
shutdown
interface ATM1/3
no ip address
shutdown
