Configure Backup Redundant link on Cisco 2951 with IOS 15.0
baqarbeezee
Hi all,
First of most I wanna discuss our scenario
We have 6 sites which are connected through E1 links.
All sites connected from HQs.
Site A is HQs.
Sited B, C, D, E, and F are Branches.
Site A is directly connected with site B, C, D and E.
Site D is connected with Site F.
Now we have another redundant E1 link for site C and Site F.
we are using Static Routes.
i have configured Qualified-next-hope on Juniper Router but i am unable to configure IP SLA on Site C Cisco 2951 with IOS 15.0 router.
is there another solution for my scenario plz share with me for Redundant Link.
Thanks in advance.
Baqar
cadet alain
if these are point-to-point interfaces then no need for IP sla because the line protocol of the interface will be down if the other end of the link is down.
So just using a floating static route without tracking the primary would suffice, you can also use the backup interface command on the Cisco device:
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_backup_serial_ps10591_TSD_Products_Configuration_Guide_Chapter.html
Regards.
Alain
