Configure Loopback on 1941
Greg Maaaag
Hello everyone!
I've got some 1941 ciscos set on every branch.
We have native L2 between this offices and I want to use external ip addresses on gig 0\0 interfaces anfdf local ip addresses on lo 0 interfaces, and use lo 0 for vpn connections.
I do:
int gig 0/0
ip add 192.168.181.14 255.255.255.0
ip nat outside
I can ping it from local network behind giga 0/1 but i can't ping it fro outside, how can i do this?
patrick.preuss
Cam you please provide more Details about what Networks and The Config. Regarding what you what to so. Maybe a drawing will help.
Patrick
Shure)
version 15.2
hostname vo
boot-start-marker
boot system flash:/c1900-universalk9-mz.SPA.152-2.T.bin
boot-end-marker
no aaa new-model
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp excluded-address 192.168.200.0 192.168.200.100
ip dhcp pool pool
network 192.168.200.0 255.255.255.0
default-router 192.168.200.12
dns-server 192.168.240.100
ip flow-cache timeout active 1
ip cef
crypto pki trustpoint TP-self-signed-1150895397
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1150895397
revocation-check none
rsakeypair TP-self-signed-1150895397
crypto pki certificate chain TP-self-signed-1150895397
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31313530 38393533 3937301E 170D3133 30313137 31343235
  30375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 31353038
  39353339 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CF84 99BF3D83 04319C0F C0A0CB94 995F790E 1CB35E02 E61DB82D C7F802D6
  2CED4FB4 15F23851 CC2B34CD 4D5F361B 7A30D2F8 358E1FDC C249302F 3610C37D
  3785084A 11313A21 51AA45B8 82E7FB12 6F193865 78169750 29C395CF 417CECFF
  CDF01641 4B8C76C7 4983BC23 500D17F4 AC10A7E5 9AD9603C 4FC8CF74 407562C7
  308F0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14448C26 307AF176 92606BCB DFAB80EB 15780CD7 C7301D06
  03551D0E 04160414 448C2630 7AF17692 606BCBDF AB80EB15 780CD7C7 300D0609
  2A864886 F70D0101 05050003 8181009B 0524D36D FCD95DF3 3C8686F3 AD1A5671
  C9E5D263 9019CC62 2DDCCD36 DA653B33 3507E515 CEAC360F 12581860 E984A649
  322BF087 FB33B1C1 28DCEA0A EF1E1F24 C583D51B C10C1902 17A2B3FB 5B203965
  1931F5D9 6076F9E4 C96621E3 8858A2FE F0822C7A 19171797 A44FE809 E8446C71
  C37495F1 60D53B93 21D8F3B5 F16E6B
        quit
license udi pid CISCO1941/K9 sn FCZ164791BM
license boot module c1900 technology-package securityk9
username * privilege 15 secret 5 $1$imo6$9fM0TAUd6GX9liR2Hp6//.
redundancy
class-map match-any VOICE-CONTROL
match ip dscp cs3
match ip dscp af31
match protocol rtcp
match protocol mgcp
match access-group name VoIP-Control
class-map match-any pcoip
match access-group 107
class-map match-any voice
match ip dscp ef
match access-group 105
match access-group 106
policy-map qos
class voice
  priority percent 20
  set ip dscp ef
class VOICE-CONTROL
  set ip dscp cs3
  priority percent 10
class pcoip
  priority percent 20
crypto isakmp policy 10
encr aes
hash md5
authentication pre-share
group 2
crypto isakmp key 6 * address *
crypto ipsec transform-set myset esp-aes esp-md5-hmac
crypto map vpn 80 ipsec-isakmp
set peer *
set transform-set myset
match address 102
interface Loopback0
ip address 192.168.181.13 255.255.255.0
ip nat outside
ip virtual-reassembly in
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address * 255.255.255.240
ip flow ingress
ip nat outside
duplex auto
speed auto
crypto map vpn
service-policy output qos
interface GigabitEthernet0/1
ip address 192.168.200.12 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http secure-server
ip flow-export source GigabitEthernet0/0
ip flow-export version 5
ip flow-export destination * 9996
ip nat pool switchvox 192.168.200.5 192.168.200.5 netmask 255.255.255.0 type rotary
ip nat inside source list 100 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.200.5 443 * 443 extendable
ip nat inside source static tcp 192.168.200.5 22 * 2222 extendable
ip nat inside source static tcp 192.168.200.5 5060 * 5060 extendable
ip nat inside source static tcp 192.168.200.20 7000 * 7000 extendable
ip nat inside destination list 105 pool switchvox
ip route 0.0.0.0 0.0.0.0 *
ip access-list extended VoIP-Control
permit tcp any any eq 1720
permit tcp any any range 11000 11999
permit udp any any eq 2427
permit tcp any any eq 2428
permit tcp any any range 2000 2002
permit udp any any eq 1719
permit udp any any eq 5060
ip sla 1
icmp-echo * source-interface GigabitEthernet0/0
threshold 2
timeout 2000
frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo * source-interface GigabitEthernet0/1
threshold 2
timeout 2000
frequency 5
ip sla schedule 2 life forever start-time now
access-list 100 deny   ip 192.168.200.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 100 deny   ip 192.168.200.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 100 deny   ip 192.168.200.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 100 deny   ip 192.168.200.0 0.0.0.255 192.168.181.0 0.0.0.255
access-list 100 deny   ip 192.168.200.0 0.0.0.255 192.168.240.0 0.0.0.255
access-list 100 permit ip 192.168.200.0 0.0.0.255 any
access-list 102 permit ip 192.168.200.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 102 permit ip 192.168.200.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 102 permit ip 192.168.200.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 102 permit ip 192.168.200.0 0.0.0.255 192.168.181.0 0.0.0.255
access-list 102 permit ip 192.168.200.0 0.0.0.255 192.168.240.0 0.0.0.255
access-list 105 permit udp any any eq 5062
access-list 105 permit udp any any range 10000 20000
access-list 105 permit udp any any range 4000 4999
access-list 105 permit tcp any any eq 5222
access-list 105 permit tcp any any eq 843
access-list 105 permit tcp any any eq 5269
access-list 105 permit udp any any eq 1194
access-list 105 permit udp any any eq 4569
access-list 106 permit ip any * 0.0.0.3
access-list 106 permit ip any 192.168.181.0 0.0.0.255
access-list 107 permit ip any host *
route-map vpn permit 10
match ip address 102
snmp-server community * RO
snmp-server ifindex persist
snmp-server enable traps entity-sensor threshold
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
