Configure Management Port ISR 4331
Elopower123
I'm trying to configure my ISR 4331 router. I'm configuring the management port to use it as the port connecting to my internal routers through iBGP. I have put an IP on the port and have connected a cable to it. But when I try to ping the IP I put on the port it times out even though the interface is up.
When I do the sh run command I see "vrf forwarding Mgmt-intf" under the port.
Can someone pls assist me on how to configure this so that I can use it as a normal port.
15 Replies 15
Giuseppe Larosa
Hello @Elopower123 ,
you cannot use the management port for  iBGP and user traffic
It can be used only for management
if you use
ping vrf Mgmnt-intf <ip-address>
you will be able to ping it but no chance to have an iBGP session over it.
Use a subinterface on a standard interface for this
Hope to help
Giuseppe
Hi Larosa,
Isn't there a way I can remove the interface from that vrf instance so that it functions as a normal interface?
Hi Larosa,
Could you explain more on how this subinterface would work exactly. I have three WAN connections to bring up and a LAN connection (ie the iBGP). And from everything you've said I seem to have only three ports.
(Hopefully Giuseppe won't mind if I answer your question first.)
Are you familiar with switch trunk ports?  If so, a router port with subinterfaces is, more or less, their version of the same concept.
What you need to do, is have some device on the other end of the router's port, the one with subinterfaces, logically have two (or more) links on the one physical link.
If you're using Ethernet for any of your WAN links, often the way this might be done is have two or more of those links, and perhaps the LAN connection, connect to a local switch.  Then on the switch, define a trunk port which connects to one of the router's ports.  On the router, you define that port with subinterfaces, each of which you normally use .Q encapsulation (to match the switch's trunk port VLANs also using .Q encapsulation).
On router:
interface g0/0
!"native", i.e. untagged
ip address x.x.x.x
interface g0/0.2
encapsulation dot1Q 2 !does not need to match interface ".#", but doing so is a good practice.
ip address x.x.x.x
interface g0/0.33
encapsulation dot1Q 33
ip address x.x.x.x
Just like a switch's trunk port, since multiple logical links are sharing a physical port, keep in mind bandwidth usage.
BTW, it's also possible, I believe, to Etherchannel between the router and switch, while still supporting subinterfaces/trunk.  This can help with sharing bandwidth "better" and provides some redundancy, at least at the physical port interface.
Joseph W. Doherty
I recall (???) some Cisco devices (of which later ones started to have the management port in its own VRF) allow you to change a management port's VRF assignment, but if so, that's really more to get the management port's IP into the global routing table.
As to using the management port as a "normal" port, I further recall (?) some routers allowed that but some or all of those routers' management port have very, very (very) low throughput capacity.
I.e. there a good chance even if you can get the management port to logically function link another routed port on the router, you'll find it cannot handle any real substantial traffic forwarding.
Elopower123
Thanks for your replies, have found a work around for the interface issue, but then another issue came up.
When my ISP advertised their full BGP table to us the router froze while receiving the routes, which was very weird. So I checked the memory using the "sh version" command and this is the output I got
cisco ISR4331/K9 (1RU) processor with 1795999K/6147K bytes of memory.
Processor board ID FLM440932DC
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3207167K bytes of flash memory at bootflash:
I guess the physical memory is up to the 4GB as advertised but I want to understand the different divisions of the memory as represented by the output and also which part or exactly how much of the memory is being used for the BGP routing.
Thanks.
I'm afraid that you need to buy a feature license to use the whole 4GB memory or there is a service module installed using 2GB
In some cases Cisco ship the branch router with full memory but then requires a license to use all of it.
But this should not be your case
see
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html
Hope to help
Giuseppe
Hi Larosa,
From the document in the link you sent the default functioning RAM is 4GB upgradeable to 16GB. I stand to be corrected but I believe this means that I should be able to use 4GB of RAM out of the box without any upgrade (just like the base throughput of 100Mbps) but then purchase a feature license if I want to upgrade it to a higher capacity.
Or am I mistaken about this?
your understanding is correct you can upgrade to 8 or to 16 GB but the base should be 4GB
Hope to help
Giuseppe
Hi Larosa,
So in your opinion where do you  think the issue may be coming from, and if you were to, how would you advise I proceed?
Hi Larosa,
Also I checked the output of the sh version command again and i saw this
"System returned to ROM by Critical software exception, check bootflash:crashinfo_RP_0 0_00_20150102-013231-WAT"
Could you please help on how I could investigate this further to gain more insight into what caused the router to freeze
if you have a valid contract for the device you can open a ticket with Cisco TAC and submit the crash info file to them.
Critical software exception is quite generic and it may mean different things:
a true software problem occurred during router operations
lack of free memory to allocate for BGP loading
Even an hardware issue related to memory
By the way, if you have NTP enabled the time of the crash file is 20150102 ?
Hope to help
Giuseppe
Hi Larosa,
If I'm not mistaken I guess a valid contract would have to mean that I got the device directly from CISCO right?
Could you please share, what is the workaround did you use here for remove "vrf forwarding Mgmt-intf" from the port? We also facing the same issue. Need to use Gigaethernet0 as a dataport.
