Configure NTP server at lab
Leftz
Level 4
Level 4
Hi we want to setup a no-internet connecting lab where there are several devices such as router, switch, and window server and work station. We want this windows server as NTP server. Can you please see the below configuration is enough to provide NTP service to all these device in the lab? and all device set NTP pointing to the server. Thanks
Select Start > Run, type regedit, and then select OK. In the pane on the right, right-click Type, and then select Modify. In Edit Value, type NTP in the Value data box, and then select OK.
the above sounds incomplete. The link below describes how to set up a Windows server as an NTP server. Once you have done that, configure:
ntp server x.x.x.x
on all devices (where x.x.x.x is the IP address of that Windows server)...
How to configure an authoritative time server in Windows Server
https://docs.microsoft.com/en-us/troubleshoot/windows-server/identity/configure-authoritative-time-server
