Configuring a Route for one host
gkonheiser
This is probably something very easy so sorry for posting here but how can I confure a route for a specific host? ie I have 2 WAN links out to the internet, the default route is one of  them and I would think one host to use the other?
11 Replies 11
cadet alain
eg for a host route to 192.168.2.1/24: ip route 192.168.2.1 255.255.255.255
But don't forget the router will always use the specific match to forward to a destination so in your case the host route on the other WAN link, I suppose this is what you want to achieve.
Regards.
Alain.
Thanks for all your help. so ie:-
ip route 192.168.1.73 255.255.255.255 62.2.34.42
so all trafic to and from 192.168.1.73 will route thou 62.2.34.42, not sure what you mean about " the router will always use the specific match to forward to a destination"
You can use two route statement for two different ISP
Bhadresh
Will the static route have a higher metric then my default route? ie it will take this route above my default route?
Both has the same metric, you can write both default route.
Bhadresh
i can try this way,
access-list 101 permit ip host 192.168.2.1 any
access-list 102 deny ip host 192.168.2.1 any
access-list 102 permit ip any any
ip nat inside source-list 101 interface gi0/0 overload
ip nat inside source-list 102 interface gi0/1 overload
where gi0/0 and gi0/1 have different ISP.
Thanks, this  is a good way of doing it instead of using ip route,
This wont interfere with my current access-list and routing?
This entry in the routing table will be used for traffic to the prefix in the static route, routing is always about destination IP not source.
When the router has multiple entries it could use to forward traffic to a destination it will always use the entry with the longest match that is which has the most bits in common with the destination IP.
Then if it has equal longest matches it will use either metric if these routes were learned from the same protocol or Administrative Distance if it was learned from different protocols and each time the lowest value wins.
Now what do you want to do exactly? NAT is not Routing and routing is done first before NAT so you can do NAT overload on your WAN interfaces but if you don't have a route going the second link then you won't NAT on this one.
Alain.
Sorry for the delay. So I have two ISPs going into my 1841, eventual I will  get them configured for either load balancing  or Failover but for now  I would just like to test one of the links, witch has just been upgraded. To do this I wanted one client, ie one of my PCs, to just use that link/interface as its route out to the internet.  I tryed the this :-
But it didnt work with my current config. SO I am still thinking about how to best go about it or just to go ahead and configer for load balancing?
Gordon
If you let me know your current configuration I can assist you better.
But make sure you have the route toward ISP including the following configuration.
