Configuring A Trunk Port on 2800 ISR
frivers
I'm lost here.  I popped open my brand new 2821 ISR router yesterday and went to configure it and something just isn't right.  Half of the commands I'm trying to use aren't available.  So the only recourse I have is to find out what the router can do and then solve the issue I'm having with it.  Here's my issue:
I have a trunk port coming from my ISP's router.  They split the traffic into two VLANS: 360 and 560.  VLAN 560 shoots everything to the Internet and VLAN 360 dumps everything into our MPLS cloud.  I have two gigabit ports (G0/0 and G0/1).  G0/0 will connect to the LAN and G0/1 will be the trunk port.  I need to be able to tag traffic coming off of G0/1 as either VLAN 360 or VLAN 560.  What do I need to do?
Hello Frank,
the only alternate way would be to add an external LAN switch and to use three ports on it:
port 1  is a trunk carrying vlan 360 and vlan560 and connects to provider
port 2  is an access port in vlan 360 and connects to C2800:g0/0
port 3 is an access port in vlan 560 and connects to C2800:g0/1
you cannot use a serial port as a LAN interface
you could consider to use an HWIC that gives some switch ports like etherswitch module
But I strongly recommend to upgrade the IOS.
you need to go to download SW -> Branch routers - > C2851 - > 12.4T
for example a 12.4 20T2 ip base
http://tools.cisco.com/support/downloads/go/SftAdvisory.x?defAdv=N&sftAdv=Y&filename=c2800nm-ipbasek9-mz.124-20.T2.bin&advUrl=http://www.cisco.com/web/software/DefTracker/280805679/SA/ac104262.html&defInd=N&mdfid=279120798&sftType=IOS+Software&optPla...
you cannot use the link as it is
the first thing to do is to add to your CCO login the service contract of the router in order to be able to download sotfware
Hope to help
Giuseppe
19 Replies 19
Jerry Ye
Assuming both VLAN 360 and VLAN 560 are tagged
interfce g0/0
no ip address
interface g0/0.360
encap dot1q 360
ip address x.x.x.x x.x.x.x
interface g0/0.560
encap dot1q 560
ip address y.y.y.y y.y.y.y
HTH,
jerry
The encapsulate command isn't available.  Is my version of IOS gimped or something?
Possible, what image are you running?
jerry
Version 12.4 13r T11
Can you post the output of show ver?
jerry
Just to make sure that you are doing it right.
The encapsulation dot1q is only available on the subinterface and it makes sense only on the subinterface. So are you checking the command on the main interface and finding it not there?.
Shahal.
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(15)T12, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 22-Jan-10 02:04 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
ABT_OPS uptime is 1 day, 1 hour, 14 minutes
System restarted at 15:11:28 PCTime Tue Apr 13 2010
System image file is "flash:c2800nm-ipbase-mz.124-15.T12.bin"
Cisco 2821 (revision 53.51) with 514048K/10240K bytes of memory.
Processor board ID FTX1413AJTF
2 Gigabit Ethernet interfaces
1 Serial interface
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
126976K bytes of ATA CompactFlash (Read/Write)
Shahal.
I've drilled down as deep as I could and still nothing.  All I see is "dot1q".
Hello Frank,
I'm afraid it is a question of feature set
I've checked on one of our 2821
sh ver | inc image
System image file is "flash:c2800nm-spservicesk9-mz.124-3i.bin"
Here I can use enc dot1q XX under a subinterface
you have the IP base feature set
Hope to help
Giuseppe
How can I get the full feature set?
I was thinking the same thing Giuseppe said, about the feature set. However, the Software Advisor off CCO said 802.1q is supported in IP Base.
About getting full feature set, legally, you have to pay for it.
jerry
Where can I get it from?
Once you have your Cisco.com login, you can download it off
http://www.cisco.com/cisco/web/download/index.html
HTH,
jerry
Hello Frank,
taking in account Jerry's note, you can try to upgrade to  later 12.4T IP Base image for free and see if this solves
Hope to help
Giuseppe
