Configuring BGP
How to configure more than 2 autonomous systems that may have same internal network IP? I have configured 3 AS : 100, 200 and 300 respectively. AS 200 and AS 300 have the same internal network. Now when I send a packet from AS 300 to AS 100 , the packet reaches the right destination but the acknowledgment reaches the wrong AS that is AS 200. AS 200 and 300 have the same internal network that is 10.1.1.0/24. Each router in AS is also configured as DHCP . The interfaces connecting the three routers via switch are on networks 15.1.1.0/24. On AS 200 the excluded IP addresses are in range 10.1.1.2 to 10.1.1.100 .Please help!
omz
! AS200 or AS300 router
int GigabitEthernet0/0/0
 ip nat outside
int GigabitEthernet0/0/1 ip nat inside ip nat inside source list 1 interface GigabitEthernet0/0/0 overload access-list 1 permit any
if you are excluding ip addresses from dhcp pool .. exclude the address assigned to the router interface as well ..
see attached .. hope that helps
omz
You could configure NAT or MP-BGP with VRF if you are advertising the same internal subnet from 2 locations.
It would be easier to just NAT the internal network
omz
 ip nat outside
Hello
@omz  Although this is just a PT simulation, I would just like to add that the use of "any any" in a ACL used for NAT statements isn't really supported and not a recommended.
Kind Regards
Paul
