Configuring EIGRP on ethernet interfaces
sifurobbie
Level 2
Level 2
Hello Cisco Support Community,
Is it possible to create an EIGRP lab using routers which have ethernet interfaces only? None of my routers have serial interfaces. Labs I've seen on the Internet use routers which use serial interfaces as well as ethernet.
Any advice is appreciated.
Rob
Rob,
The configurations look fine, but the error messages seem to indicate that you *might* have your connections crossed?
5d23h: IP-EIGRP: Neighbor 170.170.2.2 not on common subnet for FastEthernet0/0 (170.170.1.1 255.255.255.0)
5d23h: IP-EIGRP: Neighbor 170.170.1.2 not on common subnet for FastEthernet0/1 (170.170.2.1 255.255.255.0)
It's saying that you are trying to peer with your "Router C" on F0/0 which is showing "Router B" in your topology above. Can you switch these cables and try again or reconfigure the addressing?
HTH,
John
HTH, John *** Please rate all useful posts ***
6 Replies 6
John Blakley
Absolutely. EIGRP doesn't care what type of interface it's running on, it only matters what interfaces eigrp is configured to listen on.
HTH,
John
Hi John,
Thanks for clarifying that. I have the following EIGRP set up with 3 2600s to start the lab.
Once I enable EIRGP on each router I get the messages on the routers:
I have read on this forum and other posts that interfaces need to be on the same subnet. Obviously, when I configure the interfaces on Router A in the same subnet, one can't as there is an over lap. Hows does one get around please?
Many thanks in advance,
Rob
Configs of each router.
Router A
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router_A
ip subnet-zero
call rsvp-sync
interface FastEthernet0/0
ip address 170.170.1.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 170.170.2.1 255.255.255.0
duplex auto
speed auto
router eigrp 10
network 170.170.0.0
auto-summary
ip classless
ip http server
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
end
Router B
version 12.3
hostname Router_B
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip address 170.170.1.2 255.255.255.0
duplex auto
speed auto
ip address 180.180.3.2 255.255.255.0
duplex auto
speed auto
router eigrp 10
network 170.170.0.0
network 180.180.0.0
auto-summary
ip http server
ip classless
line con 0
line aux 0
line vty 0 4
end
Router C
version 12.3
hostname Router_C
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip address 170.170.2.2 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 10
network 170.170.0.0
auto-summary
ip http server
ip classless
line con 0
line aux 0
line vty 0 4
end
the config looks good.
Can you check this doc and see if it fits your topology: http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080093f09.shtml
Regards.
Alain.
Thank you for your response Alain and the article.
Rob,
HTH,
John
Hi John,
I changed the addressing and all seems fine now. Many thanks for your help. Now I can continue with the lab.
Rob
