07-16-2008 08:12 AM - edited 03-03-2019 10:45 PM
I just sold a client a Cisco 851W and he brought it back because is having problems configuring it. I have configured the same device for others clients without a problem.
I'd reset the device back to manufacture setting, followed all steps as per the user guide. When tried to configure âBasic Firewallâ at the end I got the following error at the command delivery status:
Submitting 238 commands, please waitâ¦
Class-map type inspect imap match-any sdm-app-imap
Error detected at this command. Click ok
NOTE: ISP Cable (dynamic IP)
07-16-2008 03:07 PM
does it work if you don't do IMAP filtering (you can remove it from the list of inspected protocols in SDM)
09-20-2008 03:46 AM
I am having a similar issue. Did you find a solution?
