configuring mac access-list on a router-1800
penbee
I would like to know how to block certain PCs from the network using the mac address.Any help please?
Dom
mheusing
You can use a qos policy to achieve this on a router:
class-map match-any NoAccess
match source-address mac 0011.2233.4455
match source-address mac 0123.4567.89AB
policy-map DropBadPC
class NoAccess
drop
interface FastEthernet0/0
service-policy input DropBadPC
In case the switch allows for it, you could also setup a MAC access-list on a switch to block unwanted traffic. You also could setup private VLANs on the switch, which would allow you to define which ports can communicate with which other ports finally blocking router access for some PCs.
Hope this helps! Please rate all posts.
Regards, Martin
Many thanks Martin
