Configuring Multilink
dacruzer1
Hello !
I need to configure multilink on my CISCO 4321 router.
I was told that I can bond 5 T-1s with Multilink.
I am new to multilink, so any help with the configuration would be greatly appreciated.
Background:
5 T-1s will be installed with one IP address assigned (CenturyLink)
Thanks much!
Alfred
all you need to do is add 'ppp multilink' to the participating interfaces, as in the sample config below:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/wan_mlp/configuration/xe-3s/wan-mlp-xe-3s-book/dia-media-ind-multi-ppp-xe.html#GUID-1AA7D85D-A397-481C-A9E8-83CBBBBCCE91
Thanks Georg !
Samer R. Saleem
Level 4
Level 4
Just as what Goerge wrote
you need MLPPP
Basically you will create a vitual interface then add the interfaces to it
Check this
https://pbitccie.blogspot.com/2018/10/serial-links-bundling-with-mlppp.html?m=1
Thanks Samir !
