configuring two Multicast RPs on same router for diff multicast group
s4sandyad
Level 2
Level 2
Dear all...
As captioned in title line.. we have one router in our network, having one rp 10.1.250.250 which is mapped with 4 multicast group...what working fine.
As per our new requirement, we want to use same router for one another rp address e.g. 10.1.250.251 which will be mapped with  2 diff multicast group.
we have used ip pim rp-address 10.1.250.250 command. as i will use same command with diff rp add it will override over old one. right ?
so how can i achieve this??? i tried multiple google docs but didn't find any exact useful doc. Please guide me.... or suggest short n simple doc...
S@ndy...
chrihussey
Yes you can have two RPs on the same router and define which multicast groups are to be assigned to each with ACLs. If there is an overlap there will be issues.
Here's a sample config:
access-list 7 permit 239.0.3.0 0.0.0.255
access-list 9 permit 239.0.4.0 0.0.0.255
ip pim rp-address 10.10.7.32 7
ip pim rp-address 10.10.7.64 9
Hi chrihussey
Thanks once again...
it means ip pim rp-address y.y.y.y will not override on old ip pim rp-address x.x.x.x ??
both can be work same time only mapped acl should not be overlap... right
Can you share any doc what can explore all this thing with illustration...plz
Admittedly, I can't find any documentation on this specific scenario, but I don't see why it wouldn't work.
There may be other views, but in a sparse mode environment the RP is defined by the "ip pim rp-address" command being configured on all the routers.  In truth, the RP router doesn't know it is the RP until it receives packets for sources to register or receivers to join. Whether it goes to one IP or another on the router shouldn't make a difference.
So if you have two loopback interfaces on one router and the RPs defined with ACLs, registers and joins for one group should go to one loopback and the other group to the other.
Hope I'm not steering you in the wrong direction and understand wanting to see the actual documentation. It is a little unusual but, again I can't see why it wouldn't work.
