confreg 0x2142 is not bypassing startup configuration on 4351ISR
KBMTech
So I have had a few 4351ISR units that will not enter password recovery mode. My steps are below:
  1. Power on the router
  2. Press CTRL-C until it enters ROMMON
  3. At ROMMON1> confreg 0x2142
  4. at ROMMON2> reset
The router reboots and asks for user name and password. I then try the following:
  3. At ROMMON1> confreg 0x0
  4. At ROMMON2> reset
  5. Unit reboots to ROMMON1>
  6. At ROMMON1>confreg 0x2142
  7. At ROMMON2>reset
Unit reboots and asks for User Name and Password again.
I then entered ROMMON again as I did above and tried the following:
ROMMON1>b usb0: isr4300-universalk9.17.09.04.SPA
Still asks for username and password.
I am just a bit frustrated now. Does anyone have a solution for this? Other than an hammer, of course.
KBMTech
I am sorry I have not been back for a while, but I figured it out. Our company implemented SDWAN and the routers returning to the bench had been configured in controller mode. I noticed when I ran set from rommon. It showed DEVICE MANAGED MODE = controller.  All it took was to unset that variable and set confreg to 0x2142 before the reset. I was able to log in with the admin/admin usr/pwrd combo.
7 Replies 7
Mark Elsen
 - Checkout this procedure instead : https://www.cisco.com/c/en/us/td/docs/routers/access/4400/troubleshooting/guide/isr4400trbl/isr4400trbl02.html
           (it is different from what you are currently doing)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I am sorry, this did not work.
Leo Laohoo
If the router is in ROMMON, post the complete output to the command "set".
KBMTech
Thanks for the update. Glad to know that you found the solution to your own problem.
Rick
Yeah, it did a lot for my personal pride.
