connect 2 isp internet connection on my router 2911 ISR
amralrazzaz
Level 5
Level 5
Dear all
im attaching my router configuration cisco 2911  ISR , i need to connect  2 different isp internet connection to my router
so my question is whats the additional command s that should i add on my attached file?
and what is the correct concept ? and how it work ?
- is it working 2 isp connection together ? with load balancing ?
- is it working like 1 is main and other is standby (backup connection ) in case if the main dsl 1 is down so backup dsl 2  will automatically run by it self ?
amr alrazzaz
track 1 ip sla 1 reachability
ip sla 1
icmp-echo 8.8.8.8 source-ip 100.100.100.1 what that mean ? --> this needs to be the IP address of GigabitEthernet0/1
freqency 3 what that mean ? --> this means a PING is sent every three seconds
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 100.100.100.2 track 1 track 1 what that mean ? --> this means that the route is tracked, if the IP SLA is down, the secondary default route is being installed
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/2 200.200.200.2 254 254 what that mean ? --> this is the administrative distance, it needs to be higher than that of the primary default route
5 Replies 5
typically, you would configure an IP SLA and configure one connection as active and the other as backup. I have made some changes to your configuration (marked in bold), IP addressing is arbitrary:
EGCAI01#show run
Building configuration...
Current configuration : 20694 bytes
! Last configuration change at 12:15:08 EET Mon Jan 27 2020 by amr
! NVRAM config last updated at 12:17:48 EET Mon Jan 27 2020 by amr
version 15.4
service password-encryption
hostname ------
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 5 $1$l9ha$dHLj/scp8Qm8C77UcUa/K0
enable password 7 13061E01080355
no aaa new-model
clock timezone EET 2 0
ip dhcp relay information trust-all
ip dhcp excluded-address 192.168.1.207
ip dhcp excluded-address 192.168.2.207
ip dhcp excluded-address 192.168.3.207
ip dhcp excluded-address 192.168.4.207
ip dhcp excluded-address 192.168.5.207
ip dhcp excluded-address 192.168.6.207
ip dhcp excluded-address 192.168.7.207
ip dhcp excluded-address 192.168.8.207
ip dhcp excluded-address 192.168.9.207
ip dhcp excluded-address 192.168.10.207
ip dhcp excluded-address 192.168.11.207
ip dhcp excluded-address 192.168.7.1
ip dhcp excluded-address 192.168.7.10
ip dhcp excluded-address 192.168.2.10
ip dhcp excluded-address 192.168.2.100
ip dhcp excluded-address 192.168.3.50
ip dhcp excluded-address 192.168.4.10
ip dhcp excluded-address 192.168.2.88
ip dhcp excluded-address 192.168.12.50
ip dhcp excluded-address 192.168.12.207
ip dhcp pool LAN
network 192.168.2.0 255.255.255.0
default-router 192.168.2.207
domain-name --------
dns-server 8.8.8.8 8.8.4.4
ip dhcp pool WIFI-OFFICE
network 192.168.4.0 255.255.255.0
default-router 192.168.4.207
domain-name -------
ip dhcp pool Voice
network 192.168.6.0 255.255.255.0
default-router 192.168.6.207
option 150 ip 192.168.6.207
ip dhcp pool WIFI-GUEST
network 192.168.8.0 255.255.255.0
default-router 192.168.8.207
no ip domain lookup
ip domain name --------
ip cef
no ipv6 cef
trunk group Mobile
trunk group pstn
cts logging verbose
crypto pki trustpoint TP-self-signed-2728187941
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2728187941
revocation-check none
rsakeypair TP-self-signed-2728187941
crypto pki certificate chain TP-self-signed-2728187941
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32373238 31383739 3431301E 170D3135 30333231 31333235
31375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37323831
38373934 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C184 ACFFFB46 C4C5B385 CBE1A6C9 0CD5DA07 385B1D99 C8AD86D5 9CFAA109
CACAA786 2AE1D32F CC3AC285 BBA7B419 04B2482A 0B7DD955 99130F92 48B2A075
E8B170CA 230036B1 73D4F8FF 26E2B556 6FD337BE 3A8B341B 0A80C612 6737B714
96CFA520 995A0E45 993F558D 1DFC222A 3F587ABE E3E1F038 3CA3152F F0222271
00330203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14AEA7B2 0A72790D BDCE8BF7 9C2D6CF2 C1C8A393 5B301D06
03551D0E 04160414 AEA7B20A 72790DBD CE8BF79C 2D6CF2C1 C8A3935B 300D0609
2A864886 F70D0101 05050003 81810072 94945FF4 84A78DF0 CF361867 79566C0F
D6FB48FD 3ACB218F 800D5CA1 54F4F4E2 5ED04E26 4A5DC612 097EE5D0 5A26618A
80DB770F 30768D27 C5F7679A D5E81483 C3993CC4 15CFF495 39F11F9D 7EE9054D
DC5CDEEE B3E35F53 09DB553A EACEE590 D128A220 52EE5C32 FCA5A626 BDAD34D5
6DABFE4F F30D63A5 5C92E27A 7E3EE0
quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol pass-through g711ulaw
h323
sip
rel1xx disable
min-se 3600 session-expires 3600
registrar server
early-offer forced
midcall-signaling passthru
voice class codec 10
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
codec preference 4 g722-64
voice register global
mode cme
source-address 192.168.6.207 port 5060
max-dn 64
max-pool 58
load 7821 sip78xx.12-1-1-12.loads
timezone 25
date-format D/M/Y
phone-mode phone-only
tftp-path flash:
create profile sync 0112534191700966
network-locale GB
voice register dn 1
voice register dn 3
number 120
voice register dn 4
number 116
voice register dn 5
number 100
name Inas AlMahalawi
label Inas AlMahalawi
mwi
voice register dn 6
number 101
name Meeting Room A
label Meeting Room A
mwi
voice register dn 7
number 102
call-forward b2bua noan 5 timeout 20
name Nehal Elsayed
auto-answer
label Nehal Elsayed
mwi
mobility
voice register dn 8
translation-profile incoming AMR
translation-profile outgoing AMRALRAZZAZ
number 103
name Amr Al-RaZzAz
auto-answer
label Amr Al-RaZzAz
mwi
mobility
voice register dn 9
number 104
name Khaled El Garhy
label Khaled El Garhy
mwi
voice register dn 10
number 105
name Sales 2
label Sales 2
mwi
voice register dn 11
number 107
name Maii Elsheikh
label Maii Elsheikh
mwi
voice register dn 12
number 108
name Mohammed Abdella
label Mohammed Abdella
mwi
mobility
voice register dn 13
number 109
name Nourhan Walid
label Nourhan Walid
mwi
voice register dn 14
number 110
name Karim Habib
label Karim Habib
mwi
voice register dn 15
number 114
name Tamer Mazen
label Tamer Mazen
mwi
voice register dn 16
number 115
name Raghda Kamal
label Rghda Kamal
mwi
voice register dn 17
number 106
name Conference Room
label Conference Room
mwi
voice register dn 18
number 112
name Sarah Shaker
label Sarah Shaker
mwi
voice register dn 19
number 113
name Tarek Aldessouky
label Tarek Aldessouky
mwi
mobility
voice register pool 5
busy-trigger-per-button 1
id mac 5067.AE21.4E6E
type 7821
number 1 dn 5
number 2 dn 4
presence call-list
dtmf-relay rtp-nte
voice-class codec 10
voice register pool 6
pin 4100
id mac 5067.AE21.4EA5
type 7821
number 1 dn 6
presence call-list
dtmf-relay rtp-nte
voice register pool 7
id mac 5067.AE21.9A74
type 7821
number 1 dn 7
presence call-list
dtmf-relay rtp-nte
voice register pool 8
id mac 5067.AE21.9A5A
type 7821
number 1 dn 8
number 2 dn 3
no digit collect kpml
presence call-list
dtmf-relay rtp-nte
voice register pool 9
id mac 5067.AE21.99AC
type 7821
number 1 dn 9
presence call-list
dtmf-relay rtp-nte
voice register pool 10
id mac 5067.AE21.9A52
type 7821
number 1 dn 10
cor incoming mobile-long default
presence call-list
dtmf-relay rtp-nte
voice register pool 11
id mac 5067.AE21.9A1D
type 7821
number 1 dn 11
presence call-list
dtmf-relay rtp-nte
voice register pool 12
id mac 5067.AE21.4F10
type 7821
number 1 dn 12
presence call-list
dtmf-relay rtp-nte
voice register pool 13
id mac 5067.AE21.4E15
type 7821
number 1 dn 13
presence call-list
dtmf-relay rtp-nte
voice register pool 14
id mac 5067.AE21.4DF7
type 7821
number 1 dn 14
presence call-list
dtmf-relay sip-kpml sip-notify
voice register pool 15
id mac 5067.AE21.4EAD
type 7821
number 1 dn 15
presence call-list
dtmf-relay rtp-nte
voice register pool 16
id mac 5067.AE21.4E9D
type 7821
number 1 dn 16
presence call-list
dtmf-relay rtp-nte
voice register pool 17
id mac 5067.AE21.4DD6
type 7821
number 1 dn 17
presence call-list
dtmf-relay rtp-nte
voice register pool 18
id mac 5067.AE21.4F96
type 7821
number 1 dn 18
presence call-list
dtmf-relay rtp-nte
voice register pool 19
id mac 5067.AE21.4F9C
type 7821
number 1 dn 19
presence call-list
dtmf-relay rtp-nte
no vad
license udi pid CISCO2911/K9 sn FCZ190360AM
license accept end user agreement
hw-module pvdm 0/0
file privilege 0
username ------ password 7 1511021F0C70
username ------ secret 5 $1$5Klr$GneBF.AwmAgvMY4lW/Ylk1
username aa
username Acc
username ------ privilege 15 secret 9 $9$eSfWH2ACcyEpgU$kBe69JmDRjwR01pDNDUjBF17G2JI8hOCafvoaptS8f6
redundancy
process-max-time 50
ip ssh time-out 90
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description connected to local NW-INTERVLAN
no ip address
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/0.2
description FACE-client-LAN
encapsulation dot1Q 2
ip address 192.168.2.207 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.9
description printers
encapsulation dot1Q 9
ip address 192.168.3.207 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.12
description badge-reader
encapsulation dot1Q 12
ip address 192.168.12.207 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.20
description WIFI-OFFICE
encapsulation dot1Q 20
ip address 192.168.4.207 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.55
description native
encapsulation dot1Q 55 native
ip address 192.168.5.207 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.200
description voice
encapsulation dot1Q 200
ip address 192.168.6.207 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.201
description WAN TRANSIT
encapsulation dot1Q 201
ip address 192.168.10.207 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.230
description CCTV
encapsulation dot1Q 230
ip address 192.168.9.207 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.240
description NarrowCasting
encapsulation dot1Q 240
ip address 192.168.11.207 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.250
description MGMT
encapsulation dot1Q 250
ip address 192.168.7.207 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.912
description WIFI-Guest
encapsulation dot1Q 912
ip address 192.168.8.207 255.255.255.0
ip access-group in_guest_traffic in
ip nat inside
interface GigabitEthernet0/1
description connected to PRIMARY_ISP
ip address 100.100.100.1 255.255.255.252
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/2
description connected to SECONDARY_ISP
ip address 200.200.200.1 255.255.255.252
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/GUI
ip flow-export source GigabitEthernet0/0
ip flow-export version 9
ip flow-export destination 192.168.6.195 9996
ip flow-top-talkers
top 60
sort-by packets
ip sla 1
freqency 3
ip sla schedule 1 life forever start-time now
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip access-list extended in_guest_traffic
permit ip host 192.168.3.2 any
permit ip any host 192.168.3.2
permit ip host 192.168.3.1 any
permit ip any host 192.168.3.1
deny ip any 192.168.1.0 0.0.0.255
deny ip any 192.168.2.0 0.0.0.255
deny ip any 192.168.3.0 0.0.0.255
deny ip any 192.168.4.0 0.0.0.255
deny ip any 192.168.5.0 0.0.0.255
deny ip any 192.168.6.0 0.0.0.255
deny ip any 192.168.7.0 0.0.0.255
deny ip any 192.168.9.0 0.0.0.255
deny ip any 192.168.10.0 0.0.0.255
deny ip any 192.168.11.0 0.0.0.255
permit ip any any
event manager applet PRIMARY_ISP_UP
event track 1 state up
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "no ip nat inside source list 1 interface GigabitEthernet0/2 overload"
action 4.0 cli command "ip nat inside source list 1 interface GigabitEthernet0/1 overload"
action 5.0 cli command "do clear ip nat translation *"
action 6.0 cli command "end"
event manager applet PRIMARY_ISP_DOWN
event track 1 state down
action 3.0 cli command "no ip nat inside source list 1 interface GigabitEthernet0/1 overload"
action 4.0 cli command "ip nat inside source list 1 interface GigabitEthernet0/2 overload"
snmp-server community public RO
tftp-server flash:cmterm-78xx.12-1-1-12/kern78xx.12-1-1-12.sbn alias kern78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs2.78xx.12-1-1-12.sbn alias rootfs2.78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/rootfs78xx.12-1-1-12.sbn alias rootfs78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sboot2.78xx.12-1-1-12.sbn alias sboot2.78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sboot78xx.12-1-1-12.sbn alias sboot78xx.12-1-1-12.sbn
tftp-server flash:cmterm-78xx.12-1-1-12/sip78xx.12-1-1-12.loads alias sip78xx.12-1-1-12.loads
tftp-server flash:cmterm-78xx.12-1-1-12/kern2.78xx.12-1-1-12.sbn alias kern2.78xx.12-1-1-12.sbn
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x16/FRIESLAND.png
tftp-server flash:Desktops/320x212x16/FRICOO.png
tftp-server flash:Desktops/320x212x16/FCTRK.png
tftp-server flash:Desktops/320x212x16/FCT.png
tftp-server flash:Desktops/320x212x16/TN-FRIESLAND.png
tftp-server flash:Desktops/320x212x16/TN-FRICOO.png
tftp-server flash:Desktops/320x212x16/TN-FCTRK.png
tftp-server flash:Desktops/320x212x16/TN-FCT.png
tftp-server flash:cmterm-7945_7965-sccp.9-4-2-1SR3-1/apps45.9-4-2ES26.sbn alias apps45.9-4-2ES26.sbn
tftp-server flash:cmterm-7945_7965-sccp.9-4-2-1SR3-1/cnu45.9-4-2ES26.sbn alias cnu45.9-4-2ES26.sbn
tftp-server flash:cmterm-7945_7965-sccp.9-4-2-1SR3-1/cvm45sccp.9-4-2ES26.sbn alias cvm45sccp.9-4-2ES26.sbn
tftp-server flash:cmterm-7945_7965-sccp.9-4-2-1SR3-1/dsp45.9-4-2ES26.sbn alias dsp45.9-4-2ES26.sbn
tftp-server flash:cmterm-7945_7965-sccp.9-4-2-1SR3-1/jar45sccp.9-4-2ES26.sbn alias jar45sccp.9-4-2ES26.sbn
tftp-server flash:cmterm-7945_7965-sccp.9-4-2-1SR3-1/SCCP45.9-4-2SR3-1S.loads alias SCCP45.9-4-2SR3-1S.loads
tftp-server flash:cmterm-7945_7965-sccp.9-4-2-1SR3-1/term45.default.loads alias term45.default.loads
tftp-server flash:cmterm-7945_7965-sccp.9-4-2-1SR3-1/term65.default.loads alias term65.default.loads
tftp-server flash:music-on-hold.au alias music-on-hold.au
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 1 permit 192.168.5.0 0.0.0.255
access-list 1 permit 192.168.6.0 0.0.0.255
access-list 1 permit 192.168.7.0 0.0.0.255
access-list 1 permit 192.168.8.0 0.0.0.255
access-list 1 permit 192.168.9.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 192.168.11.0 0.0.0.255
access-list 1 permit 192.168.12.0 0.0.0.255
control-plane
voice-port 0/0/0
trunk-group Mobile
no battery-reversal
input gain -6
echo-cancel coverage 24
cptone EG
timing hookflash-out 50
timing guard-out 1000
connection plar opx 100
impedance complex2
description Configured by 2911 4 FXO-0/1/0-Custom
caller-id enable
caller-id mode DTMF
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
trunk-group Mobile
no battery-reversal
input gain -6
cptone EG
connection plar opx 116
impedance complex2
caller-id enable
caller-id mode DTMF
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
mgcp profile -long
dial-peer cor custom
name internal
name pstn
name long
name mobile
name international
dial-peer cor list internal
member internal
dial-peer cor list mobile-long
member internal
member pstn
member long
member mobile
dial-peer cor list manager
member internal
member pstn
member long
member mobile
member international
dial-peer voice 8 pots
trunkgroup long
trunkgroup Mobile
corlist outgoing mobile-long
destination-pattern 904......T
prefix 04
dial-peer voice 9 pots
trunkgroup long
trunkgroup Mobile
destination-pattern 905......T
prefix 05
dial-peer voice 22 pots
service stcapp
port 0/0/2
dial-peer voice 10 pots
trunkgroup long
trunkgroup Mobile
trunkgroup Inter
trunkgroup international
corlist outgoing manager
description **Cairo**
destination-pattern 900T
prefix 00
dial-peer voice 2 pots
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
description **shortcut No**
destination-pattern 91[156789]...
forward-digits 5
dial-peer voice 3 pots
trunkgroup long
trunkgroup PSTN
description ** Services **
destination-pattern 91[1245].
forward-digits 3
prefix 013
dial-peer voice 7 pots
trunkgroup long
trunkgroup Mobile
description **Alex**
destination-pattern 903......T
prefix 03
dial-peer voice 15 pots
dial-peer voice 2000 voip
description ** Sedestination-pattern 9013.T
destination-pattern 402
b2bua
session protocol sipv2
voice-class codec 10 offer-all
dtmf-relay sip-notify
no vad
dial-peer voice 1 pots
trunkgroup pstn
trunkgroup Mobile
description ** Inside Cairo **
destination-pattern 902.......T
no digit-strip
forward-digits 8
prefix 02
no register e164
dial-peer voice 4 pots
trunkgroup Mobile
description ** Mobile **
destination-pattern 901[012]........
forward-digits 11
dial-peer voice 6 pots
trunkgroup long
trunkgroup Mobile
description **Kaluobia**
prefix 013
dial-peer voice 11 pots
trunkgroup long
trunkgroup Mobile
prefix 00
dial-peer voice 12 pots
prefix 00
dial-peer voice 21 pots
service stcapp
port 0/0/1
dial-peer voice 13 pots
trunkgroup Mobile
trunkgroup PSTN
trunkgroup long
description **Vodafone**
destination-pattern 92[47].
forward-digits 3
dial-peer voice 5 pots
trunkgroup long
trunkgroup Mobile
description **sharm alsheikh**
destination-pattern 9069......T
prefix 069
presence
sip-ua
gatekeeper
shutdown
telephony-service
max-ephones 58
max-dn 64
ip source-address 192.168.6.207 port 2000
url services http://192.168.6.220/voiceview/common/login.do
url authentication http://192.168.6.220/voiceview/authentication/authenticate.do
load 7945 SCCP45.9-4-2SR3-1S
time-zone 25
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
moh enable-g711 "flash:music-on-hold.au"
multicast moh 239.0.0.1 port 2000 route 192.168.6.207
web admin system name amr password cisco
web admin customer name amr1 password cisco
dn-webedit
time-webedit
transfer-system full-consult dss
create cnf-files version-stamp 7960 Jan 22 2020 14:10:47
ephone-dn 1 dual-line
number 111 no-reg primary
label 111
description Mr. Amr Ismaeil
name Mr. Amr Ismaeil
ephone-dn 2 dual-line
number 117 no-reg primary
label 117
description Walid Hifny
name Walid Hifny
ephone-dn 3 dual-line
number 122 no-reg primary
label 122
description Amr CIPC
name Amr CIPC
ephone 1
video
mac-address 1CE8.5DC8.D374
username "aa"
paging-dn 1
type 7945
button 1:1
pin 4100
ephone 2
video
mac-address 7001.B5DD.E0FC
username "walid"
paging-dn 2
type 7945
button 1:2
pin 4100
ephone 3
video
mac-address ECF4.BB3F.0A4D
paging-dn 3
type CIPC
button 1:3
pin 4100
ephone 5
line con 0
password 7 060506324F41
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 15 0
logging synchronous
login local
transport input all
line vty 5 15
exec-timeout 15 0
logging synchronous
login
transport input all
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server 0.eg.pool.ntp.org
end
EGCAI01#
thanks a lot sir !!
i have question for the below ip ? is it assumption ? correct because one of my isp router interface 192.168.1.1 and g0/1 is 192.168.1.2 ?  not 100.100.100.2 !! so should i use mine if im correct and ur ip addresses are an example and just copy paste them with my ip ??
ip nat outside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
amr alrazzaz
the 100 and 200 IP addresses are just examples, you have to indeed use your own. 192.168.1.x are not public IP addresses, so it seems a bit strange that you are using these for NAT ?
yes im using orange huawei router 4G and directly connected  to g0/1 , so to access this 4g router i have to go 192.168.1.1 for manage this router ,so i put 192.168.1.1 on g0/1 ?
im still waiting the main vodafone sdsl to be activated then it will be my primary dsl and the 4g router is the backup
thats why im using this ip same range of the 4g router 192.168.1.0/24
i have another question regarding the below : what does it mean as concept :
ip sla 1
thanks
amr alrazzaz
ip sla 1
