Connect Linux VM in KVM to Mininet as host
HassanAbdullah
So, I'm working on a project that requires Linux host running different programs, and a BMv2 P4 switch in Mininet.
I thought a topology as running VM in KMV with my applications running on them and connecting it to BMv2 switch in the Mininet. Is it possible to do so?? And if you, can you guide me how can I connect KVM Linux as Host to Mininet and send traffic through the switch. Any kind of help will be great.
Thanks and Regards
pieterh
you are aware this is a Cisco forum, not VMWare / Linux / Mininet?
If you're lucky, you may find someone with knowledge on this matter, but the concentration of knowledge here is about Cisco equipment,
You may have better luck on another forum
