Connected Interface are not pinging
arshad.usmani
We are connecting a Cisco 1841 router (WIC 1T) to the PE router and running an encapsulation frame-relay.
We are not able to ping between both the devices even though the connectivity is fine. Below are the observations for your reference
a) We have checked the config on the router both the DLCI is up and active still we are not able to ping the PE,
On  troubleshooting the problem, we observed
1) All the LMI status are clean, all the interfaces are up and active.
Yet, from  the routers it wont ping the other ip interfaces of the other PE serial interfaces.
When i do a debug frame packet.. I see the following from the two that dont work :
serial0/0/0.1: broadcast search
serial0/0/0.1: encaps failed for broadcast for link 38(BRIDGE)
Can you please let me know what can be the problem
Arshad
jcozzupoli
Hi Arshad,
What do you mean by "connectivity is fine"? Please elaborate!
Can you please paste the running configuration of your Serial WAN interface, both physical and sub-interface configurations.
Also, please run the following commands:
show frame-relay lmi
show frame-relay map
show frame-relay pvc
There sounds to be some kind of mismatch in configuration between your router and the SP's router, please look at your sub-interface configuration (p2p or p2mp) hit here is in your debugs "serial0/0/0.1:  encaps failed for broadcast for link 38(BRIDGE)".
However, without looking at your configurations its hard to judge, but i'd be double-checking all configurations and confirming with your SP, so both ends match up.
Joe.
Hello Joe,
Thanks for your reply. Please find the config  below
This is the current config that is in the operational router , which was online for some time , now its not accessible , the customer might have switched it off .
The same config is applied on the new router cisco :1841
CE#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            172.28.83.1     YES NVRAM  up                    up
Serial0/0                  unassigned      YES NVRAM  up                    up
Serial0/0.1                57.211.131.18   YES NVRAM  up                    up
Serial0/0.1111             57.246.104.21   YES NVRAM  up                    up
BRI0/0                     unassigned      YES NVRAM  up                    up
BRI0/0:1                   unassigned      YES unset  down                  down
BRI0/0:2                   unassigned      YES unset  down                  down
Serial0/1                  172.28.254.15   YES unset  down                  down
Ethernet1/0                unassigned      YES NVRAM  administratively down down
Dialer1                    172.28.254.15   YES NVRAM  up                    up
Loopback1111               57.220.105.226  YES NVRAM  up                    up
CE#sh run int Serial0/0
Building configuration...
Current configuration : 192 bytes
interface Serial0/0
  no ip address
no fair-queue
frame-relay traffic-shaping
no frame-relay inverse-arp
end
CE#sh run int Serial0/0.1
Current configuration : 308 bytes
interface Serial0/0.1 point-to-point
description --- to PE ****
ip address 57.211.131.18 255.255.255.252
rate-limit output 16000 8000 8000 conform-action set-prec-transmit 2 exceed-action set-prec-transmit 2
frame-relay interface-dlci 499 IETF
  class 64ke0
PE config :
interface Serial3/0/1.111 point-to-point
description --- To CE
ip vrf forwarding test
ip address 57.211.131.17 255.255.255.252
no ip redirects
no ip proxy-arp
  class 64ke0-wfq
