Connecting 2 ASA's to one Edge router (layer 3 question)
joe.hall
Hello and thanks for your assistance.
My company has purchased a second ASA for failover reasons and I'm needing to attach it to my core router (ASR 1001)
Currently I'm running the connection between my ASA and my Core as a /19   ie. ASA-10.10.10.2/19 -- ASR-10.10.10.1/19
I know the 2nd interface on the ASR will need to be on a differant network segment then the first connection (10.10.10.1/19)
What would be the best way to segment this out with out breaking up my /19?
Run /30 segments for each interface?
Use a VLan ?
I don't want to use up my Internet routable IP's on /30 segments.
Attached diagram
Thanks for the help
Andrej Zverev
If your ASA will work as active/standby you need them to be in one network segment.
Take a look into this topic https://supportforums.cisco.com/message/3726701, i think this is your solution, but be aware of BDI restrictions and limitations.
