Connecting a router via ethernet to ADSL Modem
tsalt
I have a network where I have a 2621xm router which is conencting to an ADSL Modem that is "dumb". By this I mean we need the router to set up the connection via the modem.
We have been given the logon and registered etherent address to be used for the ADSL connection.
How do we configure the router to set up the PPTP connection via the ADSL modem?
Many Thanks
Collin Clark
Thomas-
So the ADSL modem is setup to bridge correct? Here's an example config that should get you started.
interface FastEthernet0/1
description DSL WAN Interface
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface Dialer1
description DSL WAN Dialer$FW_OUTSIDE$
ip address negotiated
no ip unreachables
ip nat outside
ip virtual-reassembly
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username CORP@static.sbcglobal.net password 0 SeCrEt
dialer-list 1 protocol ip permit
HTH and please rate.
does this also work for PPPoA adsl config?
