Connecting multiple segments
rstorey4494
Community Member
Good Morning.
I've got a question on how to combine subnets. I have 3 small closed networks, all utilzing a ip range of 192.168.1.xxx
These networks have no "outside" connectivity to the world and are located in 3 seperate physical locations.
To allow me to manage the applications and such that run on these networks, I am going to bring dedicated connections into a single location so that I can access these networks remotely.
Currently, I have a Point to point T1 connecting me to one network and I utilize Cisco 1841's on either end of that. However, I will pull fiber for connectivity to the other two nets. Both buildings are withing 500 feet of me.
What I want is to have all 3 networks have a Cicso router at the "network" end and a single router in my lan room that connects to all 3. Then, I want to be able to have one or more PC's to be able to connect to any of the 3 networks as needed.
Any thoughts as to the best method to implement this? I think the router side is pretty straight forward, but the PC connectivity is stumping me for the moment.
I'm thinking I can use the routing table and mac addresses of my machines, but I'm not sure.
Bob
irisrios
Level 11
Level 11
You could configure an extended access list on the router to which those PCs are connected allowing them to access other networks.
