connecting to a DVR on separate VLAN
svt11march
Hi I've got two VLANs 192.168.1.0/24 and 11.0/24
Problem is that I wanna watch DVR with address 192.168.11.234 from 1.0/24 VLAN, but I can't ping address on the other VLAN. In this router there are route-map and ACL commands and I will show current configuration
Cisco1#show run
Building configuration...
Current configuration : 5873 bytes
version 12.4
hostname Cisco1
boot-start-marker
boot-end-marker
security passwords min-length 9
no logging buffered
aaa new-model
aaa authentication login default local
aaa session-id common
crypto pki trustpoint TP-self-signed-3138799855
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3138799855
 revocation-check none
 rsakeypair TP-self-signed-3138799855
crypto pki certificate chain TP-self-signed-3138799855
 certificate self-signed 01
  KADJSALJDLAS
        quit
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.99
ip dhcp excluded-address 192.168.1.86
ip dhcp excluded-address 192.168.1.88
ip dhcp excluded-address 192.168.1.120 192.168.1.131
ip dhcp excluded-address 192.168.1.133 192.168.1.135
ip dhcp excluded-address 192.168.1.139 192.168.1.145
ip dhcp excluded-address 192.168.1.147 192.168.1.173
ip dhcp excluded-address 192.168.1.175 192.168.1.237
ip dhcp excluded-address 192.168.1.240 192.168.1.254
ip dhcp excluded-address 192.168.1.1 192.168.1.74
ip dhcp pool AnelLocal
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server HHH.HHH.HHH.HHH  HHH.HHH.HHH.YYY 208.67.220.220 208.67.222.222
ip dhcp pool vlan11pool
   network 192.168.11.0  255.255.255.0
   default-router 192.168.11.1
ip domain name www.anel.bg
ip name-server  HHH.HHH.HHH.HHH
ip name-server  HHH.HHH.HHH.YYY
ip name-server 4.4.4.4
ip name-server 8.8.8.8
username Admin password 0
username Administrator password 0
archive
 log config
  hidekeys
ip ssh version 2
interface FastEthernet0
 description ***Link to BTC***
 no ip address
 ip virtual-reassembly
 shutdown
 duplex auto
 speed auto
interface FastEthernet0.1
 description ***Internet WAN***
 encapsulation dot1Q 462
 ip address YYY.YYY.UUU.UUU 255.255.255.252
 ip nat outside
 no cdp enable
interface FastEthernet0.2
 description ***Local WAN***
 encapsulation dot1Q 3904
 ip address ZZZ.ZZZ.ZZZ.ZZZ 255.255.255.252
 ip nat outside
 no cdp enable
interface FastEthernet1
 description Link-To-Megalan-MTEL
 ip address AAA.AAA.BB.CC 255.255.255.248 secondary
 ip address AAA.AAA.DD.EE 255.255.255.252
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet1.1
 no cdp enable
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
interface FastEthernet2
interface FastEthernet3
 shutdown
interface FastEthernet4
 shutdown
interface FastEthernet5
 switchport access vlan 11
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
 switchport access vlan 10
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$
 no ip address
 ip tcp adjust-mss 1452
 shutdown
interface Vlan10
 description ***Local LAN***$ES_LAN$
 ip nat inside
interface Vlan11
 ip address 192.168.11.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 XXX.YYY.ZZZ.AAA 2
ip route 0.0.0.0 0.0.0.0 ZZZ.HHH.YYY.XXX 3
ip route 0.0.0.0 0.0.0.0 BBB.BBB.BBB.BBB 4
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat pool MTEL XXX.YYY.ZZZ.AAA XXX.YYY.ZZZ.AAA netmask 255.255.255.252
ip nat pool MTEL11 xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx netmask 255.255.255.248
ip nat inside source route-map MTEL pool MTEL overload
ip nat inside source route-map MTEL11 pool MTEL11 overload
access-list 110 permit ip 192.168.1.0 0.0.0.255 any
access-list 110 permit ip any 192.168.1.0 0.0.0.255
access-list 110 deny   ip 192.168.1.0 0.0.0.255 host 92.247.39.81
access-list 111 permit ip 192.168.11.0 0.0.0.255 any
access-list 111 permit ip any 192.168.11.0 0.0.0.255
access-list 111 deny   ip 192.168.1.0 0.0.0.255 host 92.247.39.81
no cdp run
route-map MTEL permit 10
 match ip address 110
 match interface FastEthernet1
route-map MTEL11 permit 11
 match ip address 111
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 privilege level 15
 transport input ssh
line vty 5 15
 privilege level 15
 transport input ssh
end
ghostinthenet
Level 7
Level 7
Two things to check. Are systems on both VLANs able to reach the Internet? If you remove the "ip nat inside" statements from VLANs 10 and 11, are you able to ping across?
Jody Lemoine, Network Architect
CCIE 41436, MTCRE, MTCINE, MTCIPv6E
tishco networks, Virtually Everywhere
(905) 378-1134, jody.lemoine@tishco.ca
Yes, they're able. I don't want to remove ip nat inside, because router is currently in operation. Thank you.
I suspect that something isn't quite right with the NAT configuration. Removing the "ip nat inside" statements would have confirmed or eliminated this as a possibility, but we can look into it further without doing that.
Try replacing access lists 110 and 111 with the following and see if it resolves the problem:
access-list 110 deny ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 110 permit ip 192.168.0.0 0.0.255.255 any
access-list 111 deny ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 111 permit ip 192.168.0.0 0.0.255.255 any
