2811 router flash / memory error on bootup
living_laser
Hello
After a router reboot , found this on startup
Initializing memory for ECC
c2811 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Readonly ROMMON initialized
open: file "c2800nm-adventerprisek9-mz.124-9.T7.bin" not found
open(): Open Error = -1
loadprog: error - on file open
boot: cannot load "flash:c2800nm-adventerprisek9-mz.124-9.T7.bin"
open: file "/c2800nm-ipbasek9-mz.151-4.M9.bin" not found
boot: cannot load "flash:/c2800nm-ipbasek9-mz.151-4.M9.bin"
What does the message in BOLD means here. ?
Leo Laohoo
The error messages all point to the same thing:  The IOS file is not found in the CF.
But the router is working fine.
Can this be name of previous IOS ?
If the router is working fine then the output of show version would help identify what code version it is running. The output of show flash would be helpful in establishing what IOS image files are present in flash. And the output of
show run | include boot
would tell what images the router has been told to try to boot. One possible explanation for these symptoms is that the configuration has boot system statements for images that are no longer in flash. If that is the case then it would be easy to change the boot system commands to point to the images that do exist in flash and this error at boot time would be resolved.
Rick
Rick
If the router is working fine, then post the output to the command "dir".
Check the router's boot variable statement.  And why would the router be programmed to run an IOS for a different model of router?
