connecting two cisco routers
staphisco
Hello,   I have set up a lab of 3 physical routers.  trying to create a serial connection using crossover cable via the dsu/csu. I gave them ips and they are in the same subnet and no shut was issue but they are not up.  Please tell me what Im doing wrong.  I'm creating eigrp/ospf routing so I need to connect the 3 computers together .    BTW, im using the two g0/0 and g0/1 for internet connection so the only port left is dsu/csu.   Thx
14 Replies 14
Is that an RJ-45 to RJ-45 Serial connection? If so, you'll need them to be a "DS1 crossover" meaning that instead of crossing over pins 1 & 2 to positions 3 & 6 you instead need 3 & 4 to go to positions 5 & 6.
To diagram:
1       |  2       |  3       |  4       |  5       |  6       |  7       |  8        Position
wo     | o        | wg     | Bl       | wBl     |  g       | wBr    | Br       Starting Pin-Outs
wo     | o        | wBl    | g        | wg      | Bl       | wBr    | Br       Ending Pin-Outs for DS1 Crossover
Compared to
wg     | g        | wo     | Bl       | wBl     | o        | wBr    | Br       Ending Pin-Outs for Ethernet Crossover
Thank you but I dont understand the cabling. Please tell me what type of cable i have to buy. the back of my routers have T1 DSU/CSU port. I read that i need DTE/DCE cable but those cables dont come with an ethernet end to connect to my DSU/CSU which an ethernet port.
Please help
Thx
Joseph W. Doherty
Did you also configure one of the two serial ports with a clock?
Please help
Thx
Julio E. Moisa
If you are using serial cables you need to identify the DCE port and configure: clock rate 64000, also verify if the interfaces are UP UP using:
show ip interface brief
If they are administrately down you must configure: no shutdown under the interfaces. Example:
interface serial 0/0
no shutdown
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hello
I assume you have enabled FR encapsulation?
Example back to back FR- no FR switch
RTR1
int serx/x
encap Fr
ip address 1.1.1.1 255.255.255.252
clock rate 64000  ( this is the dce side of the cross overcable  -  show controller x/x  | in clock  to verify)
frame-relay map ip 1.1.1.2 102
no keepaive
RTR2
int serx/x
encap Fr
ip address 1.1.1.2 255.255.255.252
frame-relay map ip 1.1.1.1 102
no keepalive
res
Paul
Kind Regards
Paul
I'm not using any frame relay. This is just straight router from time warner cable.  I did encap ppp but the ports are not coming up.  I suppose I cant do the clocking because I dont have the DTE/DTC cable.  This is my question:  Do i have to buy a specific cable to do the clocking?   The crossover cannot do it because it does not define male/female who will do the clocking.
thx
Hello
I replied to this statement in your OP
For direct back to back serial connection you’ll need a dte/dce crossover cable use either FR encapsulation (example provided) or HDLC encapsulation
Res
Paul
Kind Regards
Paul
I appreciate your effort to help with this. My problem with the dte/dtc wont work because the dsu/csu port in my router. i looked at the dte end but they wont fit in with dsu port. I have attached the port of dsu/csu for you to view.
thx
thx
I got the ports up. I'm no using FR. Do I have to do clocking? This is just a crossover dce cable.
try the configs below:
R1
interface Serial0/0
description Link to R2
service-module t1 timeslots 1-24
service-module t1 linecode b8zs
service-module t1 framing esf
service-module t1 clock source internal
R2
interface Serial0/0
description Link to R1
ip address 192.168.1.2 255.255.255.0
service-module t1 clock source line
thank you for helping but im not using framerelay. This is just a crossover cable. so I decided to go with
int s0/0/0
enc ppp
ip add ....
Hello
int s0/0/0
enc ppp
ip add ....
If your crossover cable is applicable for the controller cards you are using  ( meaning not a normal data crossover cable) specific ones for E1/T1 cards then all you need to establish connection use is HDLC encapsulation as I stated previously
review this
res
Paul
Kind Regards
Paul
