connecting two routers using SHDSL
fouad-zeyad1
hello
how are you
i want to connect two routers using SHDSL using copper line
the first router is Cisco 1921 ----- CO
the second router is Cisco 888 ----- CPE
can any one help me about configuration and how to connect two routers together
1921 using RJ-45 in SHDSL slot,
888 using RJ-11 in SHDSL slot
9 Replies 9
This is a nice explanation.
http://www.cisco.com/en/US/docs/ios/12_4/interface/configuration/guide/h4wire.html#wp1131425
thanks for document
but are you try to implement this ?
i am using the same configuration but i have an error
I usually implement CPE and it works
I use this config
controller DSL 0
 mode atm
 line-term cpe
 line-mode 4-wire standard
 dsl-mode shdsl symmetric annex B
 line-rate 4608
interface ATM0
 ip address 10.10.10.1 255.255.255.252
 no atm ilmi-keepalive
 pvc 0/35
  encapsulation aal5snap
IP route 0.0.0.0 0.0.0.0 10.10.10.2
what is the cable type you used, and what is the type of router?
i try to connect cisco router 1921 to cisco router 888 using SHDSL
in 1921 ----- RJ-45
in 888 ----- Rj-11
do you have any idea to how to connect this
Cisco 888 has embedded SHDSL , but for 1921 you need to get a module.
1921 supports  HWIC-2SHDSL and  HWIC-4SHDSL  Do you have one of those module?
yes my bro
i have HWIC-4SHDSL in 1921
If you are using two lines, connect middle pins of 1921 (pins 4 and 5) to middle pins of 888 (pins 2 and 3). Middle pins are for line 0 for both router.
if you are using four lines, connect
(pins 4 to 2)
(pins 5 to 3)
(pins 1 to 1)
(pins 2 to 4)
Two assign 4 lines to a dsl group use this command
dsl-group 0 pairs  0-1
Please see the diagram attached.
Hope it helps
OK , thanks my brother
i want to try and reply
 HWIC-2SHDSL has RJ11 connector  and HWIC-4SHDSL has RJ45 connector.
Please look at picture attached to see pins arrangement If you have HWIC-4SHDSL.
Hope it helps,
Masoud
