Connection problem
Jeromy Polachak
Level 3
Level 3
Hello everyone,
I have a 2611XM router that im trying to connect to the internet. Basically its set up below.
*Cable Modem plugs into my router F0/0 port.
*Router F0/1 plugs into my switch(2950G) port one and then port 2 is then plugged into my computer.
But i am not getting it to work, what am i missing? Is the configuration needing to be set up properly? Should i be checking the switch or the router? Commands i need to type in to help you give you more information?
THANK YOU!
Jeromy
Jeromy
2 Accepted Solutions
You either need to add dns manually if you are keeping your static ip on your workstation, or change your workstation back to dhcp so you can acquire ip settings from your dhcp pool in the router.
* you beat me to it John
Thanks for your feedback and glad it's all good now. I did CCNA NetAcad and learned a lot (still learning though) from my job and doing practise labs.
The CSC forum is also a great resource for obtaining other networking folks' knowledge and experience. What you're doing is fine. Just keep it up and you'll get the hang of it.
Appreciate if you could mark this thread answered/resolved. Thanks and good luck!
26 Replies 26
Daniel Boling
Level 3
Level 3
Jeromy,
Here is an example of what Edison Ortiz is directing you towards:
! Configure the ISP-facing interface, where x.x.x.x x.x.x.x is your LANs gateway IP and subnet mask
interface FastEthernet0/0
description to isp
ip address x.x.x.x x.x.x.x
! (if DHCP: ip address dhcp)
ip nat outside
no shutdown
! Configure a default route, where x.x.x.x is the static IP of your public gateway
ip route 0.0.0.0 0.0.0.0 x.x.x.x
! (if DHCP: ip route 0.0.0.0 0.0.0.0 FastEthernet0/0)
! Configure the LAN-facing interface
interface FastEthernet0/1
description to lan
ip nat inside
! Match your LAN traffic.  Example shows the use of an ACL, where x.x.x.x x.x.x.x is your LAN subnet ID and wildcard mask
ip access-list standard INTERNET_BOUND_ACL
10 permit x.x.x.x x.x.x.x
! (example: 10 permit 192.168.1.0 0.0.0.255)
! Configure NAT/PAT for your LAN traffic
ip nat inside source list INTERNET_BOUND_ACL interface FastEthernet0/0 overload
Is this what you mean so far? I keep getting stuck on the command 10 permit ip 192.168.1.0 0.0.0.255 any (not allowing me to put the 10 in there, and not really sure why the 10 is there?)
For the private address(the inside local address) I can chose any private address right? Thanks so much so far!
description to ISP
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
description to LAN
ip address 192.168.1.5 255.255.255.0
ip nat inside
duplex auto
speed auto
ip classless
no ip http server
ip access-list standard INTERNET_BOUND_acl
line con 0
password jeromy
logging synchronous
--More--
line aux 0
line vty 0 4
login
end
description to ISP
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
description to LAN
ip nat inside
duplex auto
speed auto
ip classless
no ip http server
line con 0
password jeromy
logging synchronous
--More--
line aux 0
line vty 0 4
login
end
Jeromy
Jeromy
The command "ip access-list standard INTERNET_BOUND_ACL" will put you into standard acl configuration mode (your prompt will change from "hostname(config)#" to "hostname(config-std-nacl)#".  Once you are there, you will be able to enter the command starting with 10.  FYI: 10 is the sequence number.  You may have multiple sequence numbers, or lines, in an ip access-list.
Go back to the CLI and enter the the first command again, then the second command directly after, like this:
Router(config-if)#ip nat outside
Router(config-if)#no shutdown
Router(config-if)#ip route 0.0.0.0 0.0.0.0 fa0/0
Router(config)#interface fa0/1
Router(config-if)#description TO LAN
Router(config-if)#ip address 192.168.1.10 255.255.255.0
Router(config-if)#ip nat inside
Router(config-if)#exit
Router(config)#ip access
Router(config)#ip access-list standard INTERNET-BOUND-ACL
Router(config-std-nacl)#10 permit ip 192.168.1.0 0.0.0.255 any
% Invalid input detected at '^' marker.
Jeromy
Jeromy
maybe my IOS? Im running 12.2.
Jeromy
Jeromy
No, it was my fault.  I was typing on my iPhone during a movie...
I edited my previous post, please run the following command, then try it again:
no ip access-list standard INTERNET_BOUND_ACL
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#no ip access-list standard INTERNET-BOUND_ACL
Router(config)#10 permit ip 192.168.1.0 0.0.0.255 any
Still a no go?
Jeromy
Jeromy
Router(config)#ip access-list standard internet-bound-acl
Router(config-std-nacl)#?
Standard Access List configuration commands:
  default  Set a command to its defaults
  deny     Specify packets to reject
  exit     Exit from access-list configuration mode
  no       Negate a command or set its defaults
  permit   Specify packets to forward
  remark   Access list entry comment
Jeromy
Jeromy
I had typed standard as apposed to extended earlier, and had corrected the post.
Let's try removing any existing ACLs and start from scratch.  Please do a show running-config.  There will be a line beginning with ip access-list, copy that entire line
example:
show running-config
now, enter paste that line with the word no in front of it
example:
You should now have no ACLs (verify via show ip access-list).  Now create a standard access list:
outer#show run
Building configuration...
Current configuration : 671 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
ip subnet-zero
description TO ISP
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
description TO LAN
ip nat inside
shutdown
duplex auto
speed auto
ip classless
ip http server
line con 0
logging synchronous
line aux 0
line vty 0 4
end
Router#conf term
Router(config)#no ip access-list standard INTERNET-BOUND-ACL
Router(config)#no ip access-list standard internet-bound-acl
Router(config)#exit
Router#show ip a
02:33:28: %SYS-5-CONFIG_I: Configured from console by console
Router#show ip access
Router#show ip access-lists
Router#conf term
Router(config-std-nacl)#10 permit 192.168.1.0 0.0.0.255
Jeromy
Jeromy
You can only specify a source network address in a standard ACL. Do as below:
Leo Laohoo
Straight-through cable or cross-cross over?
johnlloyd_13
Level 11
Level 11
Remove the 'ip' keyword.
Or you can just copy and paste what was posted earlier.
Alternatively, just use 'numbered' ACL.
access-list 10 permit 192.168.1.0 0.0.0.255
I also don't see any NAT ACL in your config:
ip nat inside source list 10 interface f0/0
