Connection to Cisco 876 Router problem
giokont1974
Hi all,
I am experiencing a huge problem with my 876 cisco router.
This router was already configured to work in a small company. Now, I am trying to access it at home using either SDM or Internet Explorer but no luck whatsoever.
When I try to install SDM on both pc and router it gives a window requiring ip address, username and password. I am giving the ip (10.10.10.1 or even 10.0.0.1) plus the username/password (cisco/cisco) but the router cannot be reached.
When I try I.E. or Firefox it gives me a blank web page.
I have tried a typical UTP ethernet cable and even a cross-over ethernet cable but nothing comes up ever.
Tried this on Windows 7 and on Windows Server 2003...
What I see is that when I first power up the router, all lights go on and then only the OK light stays on and the CD is blinking. The Lan port light goes off after 30 or so seconds and the indication "cable unplugged" shows up in Windows...
Heeeeeeelp please!!!!!!
Thank you very much for your time!
P.S. Already tried the reset buton...
hi,
before accessing it via CCP or SDM you can do the following:
Router> enable
Router# config t
Router(config)# hostname xxx   ---> xxx is the router name
Router(config)# ip domain-name xxx  --->  xxx is the domain name
Router(config)# user xxx privilege 15 secret xxxx   ----> your credentials
Router(config)# enable secret xxxx ---> xxx is the privileged mode password
Router(config)# crypto key generate rsa modulus 1024
Router(config)# ip ssh version 2
Router(config)#  ip http server
Router(config)#  ip http secure-server
Router(config)#  ip http authentication local
Router(config)#  line con 0
Router(config-line)#  login local
Router(config-line)# line vty 0 4
Router(config-line)# transport input ssh
Router(config-line)# interface vlan 1
Router(config-intf)# ip address 192.168.1.254 255.255.255.0
Router(config-intf)# no shut
Router(config-intf)# ip dhcp excluded-address 192.168.1.254
Router(config)# ip dhcp pool mypool
Router(dhcp-config)# network 192.168.1.0 255.255.255.0
Router(dhcp-config)# default-router 192.168.1.254
Router(dhcp-config)# dns-server x.x.x.x  x.x.x.x  ---> x.x.x.x are the dns servers from your ISP
Router(dhcp-config)# do wr   -----> to save the config
Then connect your PC on a LAN port and configure it for getting its IP address from DHCP and launch the web GUI(
http://192.168.1.254 or https://192.168.1.254)
enter your credentials when asked.
Regards.
Alain
21 Replies 21
cadet alain
plug in a console cable and post the output of this command: show run
Regards.
Alain
mavespig
Level 3
Level 3
Hi George,
are you able to connect to the router via console?
If CD is blinking it means that the line did not train up, so you don't have WAN connection.
LAN port shouldn't go down, once IOS load is completed. If you reset already the router, your PC should get an address via DHCP, in the range 10.10.10.x, with .1 being the router. If that does not work, try to assign manually an IP like 10.10.10.2.
However, you should be able to see what's going on, once connected via console.
Cheers
Marco
giokont1974
Thank you all for your prompt answers!
I don't have with me at this moment the necessary console cable to try it out. I will have it though tomorrow and I will do as you told me to do!
I will let you know what happens tomorrow then.
Thank you very much!
giokont1974
I connected the console cable to to the router and I have no idea what to do now.......
Windows XP did not react at all once the router was connected via the console.........
What should I do now?
you need to use a terminal emulator like Putty( http://the.earth.li/~sgtatham/putty/latest/x86/putty.exe ) and connect to Serial Port COM.
do the  following: right-click on My Computer icon and select properties then select hardware tab then  device manager tab  then expand Ports( COM and LPT)  and  you'll see which port COM to use.
You'll be then in exec mode with > prompt and you'll have to type the keyword enable to get into privileged mode then type show run to view the running-config then type space bar multiple times until you have the full config displayed then scroll to beginning and left click to select while scrolling down then  paste here by right clicking.
Regards.
Alain.
giokont1974
This is what boot up, using putty, showed me: (i didnt press any key to show this stuff)
C870 series (Board ID: 6-148) platform with 131072 Kbytes of main memory
Booting flash:/c870-adventerprisek9-mz.124-6.T9.bin
Self decompressing the image : #################################################                         ################################################## [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C870 Software (C870-ADVENTERPRISEK9-M), Version 12.4(6)T9, R                         ELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 09-Oct-07 18:56 by khuie
Image text-base: 0x8002008C, data-base: 0x81AFDAC4
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Installed image archive
Cisco 876 (MPC8272) processor (revision 0x300) with 118784K/12288K bytes of memo                         ry.
Processor board ID FHK122027EP
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ISDN Basic Rate interface
1 ATM interface
128K bytes of non-volatile configuration memory.
28672K bytes of processor board System flash (Intel Strataflash)
         --- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
Press RETURN to get started!
*Mar  1 00:00:05.715: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Initializ          ed
*Mar  1 00:00:05.783: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Enabled
*Mar  1 00:00:07.647: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:08.647: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed st          ate to up
*Mar  1 00:00:13.623: %PARSER-4-BADCFG: Unexpected end of configuration file.
*Mar  1 00:00:57.823: %LINK-5-CHANGED: Interface BRI0, changed state to administratively down
*Mar  1 00:00:58.823: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0, changed state to do          wn
*Mar  1 00:36:15.103: %LINK-5-CHANGED: Interface ATM0, changed state to administratively down
*Mar  1 00:36:15.395: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C870 Software (C870-ADVENTERPRISEK9-M), Version 12.4(6)T9, RELEASE SOFTWARE           (fc2)
*Mar  1 00:36:15.395: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
*Mar  1 00:36:15.475: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Mar  1 00:36:16.279: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to do          wn
*Mar  1 00:36:16.979: %LINK-3-UPDOWN: Interface FastEthernet3, changed state to up
*Mar  1 00:36:16.987: %LINK-3-UPDOWN: Interface FastEthernet2, changed state to up
*Mar  1 00:36:16.991: %LINK-3-UPDOWN: Interface FastEthernet1, changed state to up
*Mar  1 00:36:16.995: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:36:17.979: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet3, changed st          ate to down
*Mar  1 00:36:17.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet2, changed st          ate to down
*Mar  1 00:36:17.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1, changed st          ate to down
*Mar  1 00:36:17.995: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed st          ate to down
your startup config is empty because you didn't save the running  with the wr command or your config-register is not set to 0x2102 and so the running-config is not saved.
Can you provide output of  following: show version
Regards.
Alain
giokont1974
Router>show version
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Router uptime is 18 minutes
System image file is "flash:c870-adventerprisek9-mz.124-6.T9.bin"
export@cisco.com.
Cisco 876 (MPC8272) processor (revision 0x300) with 118784K/12288K bytes of memory.
1 ATM interface
hi,
your config-register is good so you probably didn't save your running-config so you must reconfigure the router and don't forget to save this time.
Regards.
Alain.
giokont1974
Alain, thank you for your prompt answers.
How do I configure the router since I cannot access it via lan cable/dsm software?
Any guidelines to do so?
How do I save the configuration when all is done?
hi,
Router> enable
Router# config t
Regards.
Alain
giokont1974
OK. Here comes a stupid question:
Where it says xxx or x.x.x.x  x.x.x.x, what should I put? or leave it as it is with the x's?????????
x is just a placeholder, replace it by the value you wish, for example:
user xxx privilege 15 secret xxx  choose appropriate username and password
I'm going to edit the previous post to add some notes.
Regards.
Alain
giokont1974
Thank you so much for your help and I'm terribly sorry for the trouble i'm causing....
Waiting for the edited post
