continious ping from router
iqbalkhan
HI
Can I continious ping from router like windows machine ?. like 192.168.10.1 -t
Thaks
Biplob
pkhatri
Level 11
Level 11
Howdy,
You sure can. You have one of two options when doing so:
- use the standard ping command with a timeout of 0 and a large repeat count:
e.g ping 10.1.1.1 timeout 0 repeat 10000000
- use the extended ping with a timeout of 0 and a large repeat:
e.g
router#ping
Protocol [ip]:
Target IP address: 10.1.1.1
Repeat count [5]: 100000000
Datagram size [100]:
Timeout in seconds [2]: 0
Extended commands [n]:
Sweep range of sizes [n]:
Sending 100000000, 100-byte ICMP Echos to 10.1.1.1, timeout is 0 seconds:
Hope that helps - pls rate posts that help.
Paresh
You can surely use those two options, but I will not recommend that you set the timeout to 0 seconds. By setting the timeout to 0 seconds, you will most likely have a success rate of 0%. Increasing the repeat should be sufficient.
