continuous feed ASR9006
Dhikra Marghli
Level 5
Level 5
Hello
i have a ASR 9006 cisco  with 220 volt power supply chassis
I want that chassis of ASR 9006 with continuous feed
i need from expert ASR 9000  halp me and give me :
what's command that allow chassis of ASR 9006 with continuous feed !!
i wait a reply
thanks in advance
Hello @Dhikra Marghli ,
follow the instructions of the Hardware guide for ASR 9000
https://www.cisco.com/c/en/us/td/docs/iosxr/asr9000/hardware-install/hig/b-asr9k-hardware-installation-guide/b-asr9k-hardware-installation-guide_chapter_0101.html#con_1324047
the command should be
At the Cisco IOS-XR command prompt on the RSP console, run the
pwrmod_change command.
This command displays the current power module and system information.
You will have to input a number corresponding to the new power supply type and then to save/confirm your choice.
At that point you can powerf off the system and you can go on with the procedure.
If I remember correctly ASR9006 should be able to host 3  DC power supplies see in the list which option number is this.
Hope to help
Giuseppe
6 Replies 6
Dhikra Marghli
Level 5
Level 5
that means that the chassi was 220 volts .. we want to make this chassis   ASR 9006 with continuous power supply ..
what is the command on ASR 9006 alow continue feed  !! ??
Hope to help
Giuseppe
Ok  i try with these procedure and i tell you if it is ok !!
thanks to reply me !!
The problem is resolved
thank you very much
explain what you mean by 'continuous feed'.
Dhikra Marghli
Level 5
Level 5
Hello
we have power supply unit in a chassi ASR 9006  with 220 volt
then  ,  we want this power supply unit of  ASR 9006 chassis with 48 volt   with  direct current !!
what's command that allow chassis of ASR 9006 with continuous current 48  volt  !!
i wait to reply and help me for this problem of ASR 9006 !!
