Control Internt High Speed Wan Bandwidth
engahmedfakhry
Hello guys
I am going to upgrade my Internet Speed to be 8 Mbps and i need to know how to divide it per application
For example :
2 M for Download
2 M for Mail Exchange
2 M For a site to site VPN tunnel
IS it possible ????
I appericate if you can provide me with an article , documentor cconfiguration CMDs  to do this
Thanks in Advance
mavespig
Level 3
Level 3
that depends on which kind of WAN connectivity you have, you will need to discuss with your service provider if the option in available.
For example, on ATM links different PVCs can be provided by the ISP, and you can use each of them for a specific type of traffic.
For E1/T1 you can split the channel-groups and so on.
If ISP cannot provide such service, then perhaps you may just add CBWFQ QoS to reserve bandwidth for specific type of traffic. See for example:
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t5/feature/guide/cbwfq.html
Cheers
Marco
