Convering Cisco Show commands into json file
hi everyone ,
i need to convert cisco cammand outputs into json format for automation
can any one please help me on this please,
pman
maybe netmiko ?
look at the next link, The print should return as JSON format
json.dump() - converts the Python objects into appropriate json objects
https://layer3life.wordpress.com/2021/02/18/json-with-python-and-netmiko/
i had tried , netmiko and textfsm wayfor  handling cisco config to  json  but it only supports few cisco commands  no ipv6 commands are seen
