Copy flash TFTP Error
terrelstinnett
I have a 3550 switch that I am trying to upgrade the IOS on.
I am trying to copy to a TFTP server.
I am receiving a socket error.
I saw that this can be fixed with
Switch#config t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#no service config
Switch(config)#exit
Switch#
00:13:47: %SYS-5-CONFIG_I: Configured from console by console
Switch#reload
I have done this 3 times to no avail.
My TFTPd32 server on my pc is working fine.
Here is the error
Switch#sh flas
Directory of flash:/
     2  -rwx         556   Mar 1 1993 00:33:53 +00:00  vlan.dat
    4  -rwx        3775   Mar 1 1993 00:37:54 +00:00  config.text
    5  -rwx          24   Mar 1 1993 00:37:54 +00:00  private-config.text
    6  -rwx     5687963  Mar 16 2007 01:05:23 +00:00  c3550-ipbasek9-mz.122-25.SEB4.bin
    8  drwx         192   Mar 1 1993 00:04:40 +00:00  c3550-i9q3l2-mz.121-22.EA1a
15998976 bytes total (3300864 bytes free)
Switch#copy flash tftp
Source filename []? c3550-ipbasek9-mz.122-25.SEB4.bin
Address or name of remote host []? 192.168.1.132
Destination filename [c3550-ipbasek9-mz.122-25.SEB4.bin]?
%Error opening tftp://192.168.1.132/c3550-ipbasek9-mz.122-25.SEB4.bin (Socket error)
HELP!! THANKS IN ADVANCE
jas2061461
Level 3
Level 3
Can you ping the server from the switch?
nope, i am consoled into the switch.
my ethernet port is broken.
DSW#show int vlan1
Vlan1 is up, line protocol is down
  Hardware is EtherSVI, address is 0012.4339.a880 (bia 0012.4339.a880)
  Internet address is 192.168.1.133/24
DSW#ping 192.168.1.132
Sending 5, 100-byte ICMP Echos to 192.168.1.132, timeout is 2 seconds:
Success rate is 0 percent (0/5)
TFTPd32 has no security.
My firewall is turned off.
I dont know whats going on.
Leo Laohoo
Duplicate post.
